Bungy
Oct 2010
Minnesota
I just got an 83 TC and the engine has an 87-88 upper, lower, valve cover, brown top injectors and an E6 manifold. So my question is, were these added to the 83 engine or is the whole engine an 87-88? Where can I find the casting numbers/dates to tell for sure? Also how can I tell if it's got the large vam or small?
1986 TC 100% Stock
"Nitrous is for guys who can't build motors"
gmaibach
Sep 2008
Sterling, Ohio
what kinda turbo is it
1988 Turbo Coupe 5 speed Red with Red cloth interior, K&N cone filter, Ported IHI turbo, ATR Header ported, Manual Boost Controller at 18 psi.
2013 Focus ST 2.0 Turbo, Buschur green filter, OCD Speed axle back exhaust.
Bungy
Oct 2010
Minnesota
It's still got the 83 turbo with no intercooler.
1986 TC 100% Stock
RC Martin
Mar 2006
Colorado
What style of intake manifold? If it's the 87/88 style then it probably has an 87/88 head on it. Not sure the bottom end would even matter which year it came from... Also, you can measure the diameter of the VAM on the intake side. I forget which is which size, but the big VAM is closer to 3" I think.
Question: what are you worried about? My 84 TC had a Ford rebuilt ~86 engine in it when I bought it (Ford pistons and bored .020 over), didn't realize that for my first couple years of ownership haha. I'm assuming the original owner blew up the first engine and paid out the a$$ to have Ford put in a new one.
Bungy
Oct 2010
Minnesota
I never said I was worried. After I saw the brown top injectors, I just started wondering what else the previous owner swapped. Did he also swap the VAM? Did he also swap the EEC? I'll have to wait till the 3 feet of snow melts off it to start digging around and find the computer. Maybe if I get bored, I'll clear off the hood and measure the vam opening.
Thanx guys.
1986 TC 100% Stock
86XR7auto
Mar 2003
Mt. Pleasant, MI. USA
I would just remove the computer from the kick panel. These cars will run with wrong computer and wires hooked up. Who knows what the previous owner did.
The opening on the small vam are 2.75" vs 3.00". Hope that helps you.
Travis
