what does code 81 mean?
r3lic76 Offline
my "check engine" light goes on after about 5 minutes of driving, and it stays on mostly......and the only code that came up was 81
the guy who dropped my motor in doesn't understand it, and me and Pathogen consider him the best at 2.3L and 5.0 around this area (but he doesn't go online)
please help with suggestions......pathogen said it might be a sensor on the lower intake (not the knock sensor...but could be)
88 Turbocoupe - T3 conversion - bbk255 - kirban FPR - open 3" dp - ported lower intake
KMcGrathNJ Offline
Code 81 -
Thermatic Air Diverter (TAD or AM-2) solenoid circuit failure, or Electro-Drive fan circuit failure, or Intake Air Control (IAC) valve circuit failure, or Boost solenoid circuit failure
Kevin
88 TC T5;White/Red; All options exept Leather; Front Mounted K&N cone filter; 140 Speedo; Superchip; Gillis Boost Valve; Custom vac/boost-volt-temp gauge cluster in console Ground Effects; Spoiler; Blaupunkt H/U; Boston Accoustic 3 1/2" in dash; Polk 6" in doors; Infinity 5 1/4 component in rear deck;
Rockford 10" sub; (2) Alpine amps
Near Future -Paint
You don't have thermactor so that's out.
Does your passenger side cooling fan come on for a couple seconds each and everytime you start the engine. It should. If it doesn't
I'd start there. If it does then you should look at the two remaining choices. Do you have an after market boost control valve? Is the harness still plugged into the original BCS? If it isn't it will throw a code.
[This message has been edited by Pete D (edited 07-06-2002).]
r3lic76 Offline
yes my friend has a boost valve plugged on my car. i'm not familiar with all the terms yet, i only know what about the O2 sensor, EGR, and WGA.
the boost valve hose attaches to the turbo housing towards the bottom, and that hose connects to the actual valve, and then the hose goes up and plugs in at the top (i dont know the name, but a few other vacume hoses connect there also)
thanks for the help
**PathogeN** Offline
The gillis valve is hooked up but the stock BCS is gone (not plugged in). Rule that one out.
ADD: Its probably the IAC. I forgot all about that. Idle racing on occasion too. We'll check that tonight.
[This message has been edited by **PathogeN** (edited 07-07-2002).]
88 Turbo Coupe (White)
88 Psudo Coupe (Silver LX)
KMcGrathNJ Offline
I hope you guys figure it out. I think that was Pete's point that if it isn't there and plugged in. it will throw a code
Kevin
Near Future -Paint
r3lic76 Offline
The IAC isn't the problem because we plugged in a brand new one and i still got the "check engine" light after 5 minutes of driving
i dont understand the part about passenger side fan, that Pete D said. Also, my boost valve goes like this: vacuum tree --> valve --> vacuum inlet on turbo
KMcGrathNJ Offline
The point about the boos valve is that there was an electrical connentor that went to the solenoid, that cannot be connected to the after market valve. That is why it will send a code, because there is no reading from the connector. This however should not have anything to do with the check engine light.
As far as the fan, as pete said the fan on the pass. side should come on for a few seconds when you start the car. Just check that by direct observation.
Kevin
Near Future -Paint
Is the code 81 a KOER code? a KOEO current fault code or a continuous memory code?? If the CEL stays on and then goes off, there will for sure be a continuous memory code stored. Is that where the 81 is from?
It is IMPORTANT to explain exactly what part of the test the code came up in..... they often have different meanings in KORO, KOER, continuous memory.
r3lic76 Offline
code 81 comes up right when i start the test, which i think is memory code
i plugged the stock BCS back in and i still get a check engine light
