What a wonderful week.....(Long)
Spooler87 Offline
In a nutshell, here's how my week has gone so far....
I was on my way to a friends house to fix some interior parts when A truck dumped something hard out of the back end... i Tried to swerve, but i caught it on the drivers side tire...at 70 MPH. The tire blew straight across the tread, and my snowflake is cracked most of the way across. So I figure, well, at least I didnt dump the mini spare last week....Until I start driving on that and it blows as well.... So .
I drive two miles down the interstate on a blown mini spare... call the junk yards and nobody has wheels for my TC... Dammit. I was stuck for two days about 70 miles from home until I found a set of wheels at a yard that said they didnt have them. They were off of a 87 TC....the problem is that they are 14" wheels. They are some kind of aftermarket....they remind me of Welds. Anyways luckily for my pocketbook, all four tires still held air, but are pretty much shot (Dry rotted, bad tread, soft sidewalls) But i'm having them replaced tomarow. Now the Questions. Are there any major problems I should look out for (Driveability) with the smaller wheels? They are on the car now, but my car feels like I'm driving on underinflted tires....it shimmeys when i move the wheel back and forth at speed. Could that just be because the tires are junk?? I Know my speedo will read fast by about 7% (60MPH on the speedo, about 54MPH actual speed) Anything else I should watch out for??
87 Tubocoupe, Light Regatta Blue, All Options incl. Leather; 2.5" exaust, Dynamax super turbo mufflers w/3"chrome tips, MSD 6AL, Blaster2 Coil and wires, Homemade adjustable boost valve.
"May the fluids under the hoods of the beleivers flow forever"
All hail Project "Marauder" !
tr_guy79 Offline
I was under the impression that 14's wouldnt clear the calipers..?? Make sure you use all 4, other wise you *may* find problems in the ABS. Other than that, and less ground clearance, I dont know of any other problems. Of course I dont know everything either...
3rd Annual Philly Tri-State NATO Meet - http://natomessageboard.com/ultimatebb.p...p=1#000003
'87 - Range Roller 4* adv / 50 trim t04e / Ported E6 / Gutted Knifed intake / Stinger 3->2.5" / Adj. Cam Pulley / Warlboro 255
To Do: PIMP/MS2, FMIC, Bigger Inj
Glenn 88TC Offline
My 15" draglites rub the bolts on the caliper.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
tr_guy79 Offline
Thought so. Spooler, Do you have the 14's on it now??
Spooler87 Offline
Yup. They actually came off a junked TC in the boneyard....No rubbing, absolutely no problems so far. They are not hub-centric, however thats not a problem if you torque them while off the ground. They are shod in some ratty-looking Uniroyle (Spelling) Tigerpaw GTS tires, size is 195-70/14 I Had also read on Eric's site that 14" wheels are too small for our cars...no change in calipers or rotors from stock. Mabey i ust got luckey! heheh
