How quickly does it boost to 10 psi? If the WG itself is stuck partly open, it will spool very slowly. If the WG is fully shut, and you have no boost leaks (IC hoses, etc), the turbo could be bad. Pull the inlet elbow and see if it looks like the compressor fins are hitting the housing.
