Weird problem with headlights. Not the switch.
MikeSak Offline
The low beams are very dim and they keep burning out. The high beams work fine. I checked the grounds on the core support on both sides and they looked fine. Any ideas or trouble shooting ideas would be much appreciated.
-Mike
88 TurboCoupe
86 Mustang and Capri
91,92, & 93 Explorer Sports
91 & 92 Rangers
00 Explorer - The winter beater
Apparently I'm a late 80's-early 90's Ford collector.
tr_guy79 Offline
Could be the Multifunction switch....
3rd Annual Philly Tri-State NATO Meet - http://natomessageboard.com/ultimatebb.p...p=1#000003
'87 - Range Roller 4* adv / 50 trim t04e / Ported E6 / Gutted Knifed intake / Stinger 3->2.5" / Adj. Cam Pulley / Warlboro 255
To Do: PIMP/MS2, FMIC, Bigger Inj
Dim bulbs should last longer than bright bulbs, since the dim filament is running at a lower temp. Are you touching the bulbs during the install? Is there any water in the headlight housings? Either of these will kill a Halogen bulb in short order.
A volt drop test will tell you why the lights are dim and where the problem is.
MikeSak Offline
The multifunction switch is new, the bulbs were installed clean, and the housings are moisture free. I guess I'll break out the multimeter and see what I can figure out.
-Mike
88 TurboCoupe
91 & 92 Rangers
MikeSak Offline
After replacing the cheap sylvanias with some hella bulbs and a re aim the headlights are good again. That and I think I'm just used to the headlights on my 2010 Ranger.
-Mike
88 TurboCoupe
91 & 92 Rangers
tr_guy79 Offline
Our headlights SUCK!!! I actually pulled over and got out of my car to make sure mine were on this weekend driving around at dusk...
-Shane
Redbone Offline
I know what you mean. I constantly think I have a headlight out.
All your boost are belong to us
1988 TC 5m 3" elbow back exhaust(with cat and muffler), Walbro 255, gillis mbc, airbox removed w/ K&N cone, A/C removed, Spec clutch, Ranger roller swap.
John A.
Ballman Offline
What i did on 2 of my non stock birds , was took out the fog lights and put in the same spot and fit just great ,,, a pair of PIAA driving lights. But also had to run them off their own switch-relay that does come with the lights, just at 200 bucks a pair,, but they light up the road . Try it , you will not be sorry .
or just buy a new set of headlights if you want to keep the stock fog lights, either set will be 200 bucks ..
D.Wilder
DW
