Weird no start issue
JackV Offline
ok so i have an 87 turbo coupe 5 speed, and i'll drive for like 5 minutes or so, and the car just completely dies out, it wont charge the coil there for wont shoot spark, i already replaced the coil, i replaced the fuel filter, pump, and ECT, thinking it would be them for some reason. But if i let it sit for about an hour or sometimes less its fine or another like 15 minutes or so. It just started doing it last week. i scanned for codes and nothing pops up.
has anyone had an issue like this? i need help like as soon as possible. Thanks
1987 Turbo Coupe - Stock
RDOG Offline
Could be TFI.
Check out this link. He had the same issue after a year of the car sitting. What seems like is happening is the TFI will get hot and cut off. Once it cools you can start it, but it will only run again until it gets hot again.
http://natomessageboard.com/ultimatebb.p...1;t=022641
If thats the issue I would create a remote mount setup. That will keep your TFI's from frying. There are links to how to make one in the FAQ section
zbird Offline
+1 I agree with RDOG, thats where I would start looking.
Dom Z
99 F150 4x4
14 Ford Escape 2.0L Turbo
JackV Offline
well i replaced the TFI with a known good one and its doing the same thing.
any other suggestions?
RDOG Offline
Do you have a backup PIP you can install?
Do your gauges start jumping when the car is about to die? At idle does the speedometer jump from zero to 5-10mph at a stop light when its about do die?
JackV Offline
i acutally dont have a spare PIP, but the speedo doesn't jump.I noticed that after the car dies, when i trie to start it, when the engine slows down after cranking the tach jumps up a little, but thats it.
PIP has nothing to do with the speedo. Have you run codes? Look for a CM 14 and/or CM 18. CM 14 is intermittant loss of PIP signal, and CM 18 is intermittant loss of IDM signal (coil firing signal). If the coil isnt firing, I suggest replacing the TFI and PIP with Motorcraft parts. Was the TFI you used a cheapo off brand parts store unit? In general, they are junk, and have ben known to be bad out of the box.
JackV Offline
I'll see when i can get the motorcraft parts, but like a stated, no codes have been shown
the one i replaced it with was one off my auto car,that i knew worked, and it was motorcraft.
JackV Offline
ok i noticed the dizzys have different rotors, with the PIP be the same?
Only rotors are different between years, rest of dist, including PIP, are the same for all 2.3 EFI motors.
