GaryS#2
May 2001
B.C. Canada
I got a new Beck/Arnley (not reman) water pump and the impellor is different than the old one I took off.
The old one is closed impellor design and new one is open impellor.If that makes sense.
Wich one is best and what did orig Ford look like?
Thanxs.
Grocery Getter/Rice Cooker.
By closed, you mean the back side of the impeller has a solid disk on it instead of it being just blades, right? The "closed" design is much more efficient at pumping water than thhe open design. I have seen kits in Summit / Jegs catalogs that have a metal disk and a few rivits to convert an open type to a closed type.
GaryS#2
May 2001
B.C. Canada
Ya that's it, a disc if you will.
So what came stock though?
Keith Nubel
Liberty Township, OH
Speaking or water pumps, has anyone ever tried an electric water pump? Do they make one for our 2.3?
85.5 TC 5 speed, K&N filter charger, Ranger Roller cam, 3" exhaust system, manual boost valve, large VAM, SVO PE computer, front mount intercooler & sport grille, underdrive pulley, ported upper and lower intakes,flow matched injectors, ported E6 manifold, 245/45/17 wheels & Tires,140 mph speedo, under restoration
1985 TC
GaryS#2
May 2001
B.C. Canada
You can use an inline electric and cut impeller off old one.
Chad88TC
Aug 2001
Berlin Heights, Ohio
The only thing I can thing of is that they used the open propeller design on the earlier ones and the closed one on the later cars
'88 Black, K&N on VAM, Holset HY35, ported E6, 2.5" single cat-back w/dynomax muffler, gillis, RR cam, TA cam gear, Bosch BPV, Stock IC, Walbro 255HP, Kirban AFPR
GaryS#2
May 2001
B.C. Canada
I used the open one anyway.
There was a rebuilt one that was disc type but I wanted to see if a new one lasts longer.
This one is made in Japan!LOL
