Water injection Q's
Turbobob_dup1 Offline
Has anyone here tryed it? If so how'd you build it,parts etc? Did you use a boost activated switch ?
My big valve head is almost ready as well as the gutted upper and 60mm throttle body. I think O2 inj. would be an asset for this set up.
Any help is appreciated. Glenn , Gary , Pete?
87 Turbocoupe,T3/T4 turbo,much porting,AFPR,255lph pump,GN cooler,K&N in the fender,gutted upper/knife edge lower,big valve head,roller cam,60mm throttle body,Talon 1G BPV.
87 Turbocoupe,T3/T4 turbo,much porting,AFPR,255lph pump,GN cooler,K&N in fender,gutted upper/knifed lower,big valve head,A237 cam ,60mm throttle body,Talon 1G BPV.
4 + 1 = 8!!
GaryS#2 Offline
That's H2O you mean.
O2 is oxygen. [Image: smile.gif]
I've thought about it and it sounds like a good way to go, but I've heard/read about water mist hurting cyls, rings?(shrug)
Maybe a water/alki mix?
I would use a pressure switch to activate at 10 psi or so.
There was a link somewhere to build one, can't remember WWW.
I'm playing with C02 right now because of availability and just finished perfecting my IC sprayer.
This thing works great, and I can get it to snort like a Dragon while sitting at lights.
Scares away the local rice. [Image: wink.gif]
Grocery Getter/Rice Cooker.
natmac3 Offline
If you are a member and have access to the NATO newsletters, there is a nice write-up in one of 'em, I believe care of Jeff K.
1987tc
Yup, the last NATO newsletter has a detailed write up, complete with pics of the water injection system I am using.
Damn , I was a member last year but since fell upon hard times and couldn't afford to rejoin.
4 + 1 = 8!!
