Wanna help me out Pete (timing belt tensioner)?
**PathogeN** Offline
I can't for the life of me remember how to "do" the timing belt and tensioner. I know how to time n all but how exactly do you take the tensioner and all off? And put it back on? Friend just shot my old tensioner spring across the garage somehow....hm..oops.
Thanks in advance.
88 Turbo Coupe (White)
88 Psudo Coupe (Silver LX)
Keith Nubel Offline
Do you have the tensioning tool? If not you can use a socket adaptor and fit it into the area where the adjustment bolt is. I use a socket adaptor that I ground down to fit and use a breaker bar to move the pulley.
85 TC 5 speed, K&N filter charger, Ranger Roller cam, 3" exhaust system, manual boost valve, large VAM, SVO PE computer, front mount intercooler, underdrive pulley, ported upper and lower intakes, 245/45/17 wheels & Tires
1985 TC
Well...i got the timing all done and crowbared the tensioner so its on good n tight. Worked great for about an hour of driving (some fairly hard too). I let it site and idle for a few mins in front of my house to let the turbo cool and went inside. When I came back out it was running like crap again. And theres no way the timing belt slipped this time so it must be something else. What gives? Any more ideas?
Check the timing marks just to make sure and it that's ok then pull the codes.
and jack rails.
DennySweet Offline
My 87 did this and it was bad bearing on the aux shaft! My2cents
88TC,87TC,,86S-10,82Toyota 4WD,3-88S-10Blazers.
