waist gate orfice size
matthew Offline
Does any one know what the size of the hole in the orfice that comes out of the intercooler and goes to the waistgate? I want the size of one on a manual trans not a auto or does anyone have one for a manual? this is on 88 turbo coupe.
1988 tbird turbo coupe all stock
turbospoolin23 Offline
The small threaded hole on the intercooler? 1/8npt?
matthew Offline
I meant the inside of the orfice
Are you asking about one of these? I think the top one was in the intercooler and the bottom one was in the turbo. These are off a 5spd car. http://s271.photobucket.com/albums/jj140...G_0267.jpg
matthew Offline
Yes that is what I am looking for . I need to know the inside diameter of the hole
Why? First, neither end of that T goes to the WGA. One goes to the cruise control servo via a one way check valve, and the other end dumps pressure to the turbo inlet. That thing is an asparator that generates vacuum for the cruise control under boost conditions.
matthew Offline
Ok then that is not the right part. From what I have read the T that goes to the waistgate actuator and the bcs on a manual trans has a smaller orifice size than one from a auto car. I just want to see if they are. Mine is a auto so I can compare it to mine
natmac3 Offline
Oh, that's the one that's on the compressor outlet, it has 2 barbs 90* to each other. One end goes to the wastegate, the other goes thru the stock bcs to the compressor inlet.
Don't have one here, but I'll check my "stash" later.
1987tc
matthew Offline
Yea that is it? Thanks
Nat are you talking about the bottom one in my picture? I'm pretty sure that was the one on the cold side outlet.
