WAHOOOOOOOOOOOOOOO a whole 90 horsepower!
BJL Offline
Moderator
MAN what a power differnce!
this car wont even rev near 4000rpm, it shifts to soon! that WOT!
ahh gotta love the non turbo turbo coupe.
seems good so far, needed a cat back system.
no problem for me, used a 2003 stang laft muffler, and bent up a 2in tial pipe.
hooked up the torque converter lock up.
it has a mustang engien and trans (2.3l:A4LD)
fornt universal jionts are shot, nice clang and vibrattion at decleration. front left sway bar end link is non exsistant. and needs a 2 wheel alignment.
rear differntial makes a nice howwwwwww. any recommendations on that? thicker gear oil?
nice to be back in a TC.
Brian J Larkin
1988 Non-Turbo Turbo Coupe
med gray met. raven/gray interior, fully loaded minus leather and sunroof!
converted to N/A 2.3l by previuos owner, but its a nice driver with working A/C!
remote start, sequentail turn signals, 2003 stang muff. soon to have 3g alt, stereo, k&n, maybe ported intakes and manifold
1988 Turbo Coupe 5spd
gillis boost valve, k&n cone,AFPR, 255lph, HP pump,3G 130amp alt, 3.73 gears,mild torquie cam, factory DP, 2003 mustang take off SS mufflers and custom BJL 2 1/4 tails.
(needs a front frame pull)
[This message has been edited by BJL (edited 05-20-2004).]
Brian J Larkin
88TC 320k miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
Carcrazyscott Offline
Alright, Brian is really sick. He seems ok with driving a 90hp TC. Somebody distract him at Carlisle while I swap in a turbo 2.3.
-Scott Ressler
S&R Racing www.s-rracing.com
Glenn 88TC Offline
-Scott Ressler
You heard him Brian. Bring a 2.3 turbo along to Carlisle and S&R Racing will be doing a swap how to seminar.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), Solid lifters, Esslinger roller cam #2277, Esslinger adj. cam pulley, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Spec stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
BJL Offline
Moderator
well i have a good hih turbo, and the engien out of my 83 TC sitting outside, so we could it, just its a A4LD, i acutally want to stil have usable trans,. lol
Brian J Larkin
dark blue metallic
gillis boost valve, k&n cone,AFPR, 255lph HP pump,3G 130amp alt, 3.73 gears,mild torquie cam, factory DP, 2003 mustang take off SS mufflers and custom BJL 2 1/4 tails.
(out os service due to my idiot self)
88 TC Auto, med gray met. raven/gray interior, fully loaded miuns leatehjr and sunroof!
converted to N/A 2.3l, but its a nice driver with working A/C!
Brian J Larkin
88TC 320k miles
Where's your sense of adventure? The A4LD would hold up for a little while at least.
-Scott Ressler
BJL Offline
Moderator
yea well it smy only transportation right now. my father doesnt want me to drive it to carlisle after our universal jiont ordeal and i stil have soem front brake problems, let alone it pings liek crazy even at zero degrees timing !!!!!!!!!!!!!!! ahhhhhhhhh
i hit aout 50 byt he end of each on ramp and cant relaly go! grr i want my blue tbird bakc in service!!!!
Brian J Larkin
Brian J Larkin
88TC 320k miles
