WAAAAA HOOOOOOOO!!!! SOLVED!!!!!
BJL Offline
Moderator
changed my plug wires today and put in platnium plugs!(plugs were black and one was rusted?!?!?) Now she's running perfect!!!no miss or buck, except for my miss at idle (cam does that) but its all good.
Now my next problem the rod knock and low oil pressure when running hot. I mean like hot hot, at the H. I think she over heated to much when the head gasket blew in march,
any good places to get a lower end bearing kit?????
Thanks Brian
PS: thanks to Pete D and every one else on helping me with this, i think the PIP and TFI helped allot in this today, been allot of dianostics with this car, just gotta work it through!
Brian J Larkin
88TC 320k miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
Dan E Offline
Yeah, I think I'm going to change my plugs a wire too...who knows...it may be my problem ???
Glad to hear somebody has had a success !
Dan Eaves
I would get a good kitchen thermometer and acutally measure the coolant temp. I'd also check the oil pressure with an underhood mechanical gauge. you might want to try one of those automotive stethscopes (sp). They are cheap and helpfuul for isolating noises.
Glad to hear that you are making progress.
Stick with it, you will get there.
Elite Bodega 16" chrome wheels. Autometer pod w/ A/F and Vac/boost gauges. New engine: Total Seal rings and TRW pistons, ported and polished head w/ cc'd chambers,1.59"exhausts, SS valves, gutted upper, knife edged lower, A-230 cam, Race Engineering Adj Cam Sprocket, Crowlers, ARP head studs, and rod bolts. Walbro 190 pump and T-3. Centerforce II, KB subs and jack rails.
