VSS wiring
junkedturbo Offline
Does anyone know or have a diagram of were the VSS wires lead to make it work with the speedo? A month ago i took out my dash, looked at the jungle of wiring and said it all had to go leading me to rewire the car ground up and all I have left to find out is how to run the speedo. Any help would be great.
junkedturbo Offline
So I went to the library and looked up the wiring diagram on the Tbird, I guess the VSS(-) or the O/Y wire goes to the gound and you can splice pin 6 to it and the speed control Amp. then VSS(+) or the DG/W wire goes to the speedo and you can splice pin 3 to it, the speed control Amp., and/or the trip minder.
Something interesting, when looking through the Pinouts sheet http://www.gt350mustang.com/eecspecsturbo.htm they forget pin 3 VSS-DIF(+), pin 56 PIP, and pin 57 VPWR. Don't know if any of this is helpful.
