When going with a bigger throttlebody or if you just cant find a breather to replace the clogged one you have on the 87-88 TC valve cover with the 1" breather hole grommet, the best srect and cheap replacement is the one of a 8-89 Ford Tempo or Mercury Topaz with a 4cylinder engine.
cars
http://i158.photobucket.com/albums/t97/b...b9a4b6.jpg
http://i158.photobucket.com/albums/t97/b...fc4e26.jpg
engine
http://i158.photobucket.com/albums/t97/b...6b9994.jpg
breather and grommet
http://i158.photobucket.com/albums/t97/b...995307.jpg
This one has the breather element mesh inside and also sits low so y=it clears the IAC when using a BIG Throttle body.
The grommet is also a direct replacement for a worn, lost, old, or damaged grommet for even a stock breather.
cars
engine
