So, I've owned my 88 for a little over a year now and as much work as I've done to it, I'm still discovering new things about these cars everyday. The previous owner replaced the valve cover breather with a simple K&N filter to vent to atmosphere. On my previous car (04 focus ZX3), I also vented the valve cover to atmosphere when I turboed the car. I've been reading through some forums and it seems that this set-up could create a vacuum leak since the air is not vented/routed back into the intake before the turbo/after the VAM. I've driven my 88 like this since the day I got it and haven't noticed any drivability issues. There's an occasional hard start after the engine has been running for some time but I don't know if this is even related. I want to replace the valve cover filter because 1) it's gummed up; as expected and 2) I rather not vent directly over my valve cover. Should I route the VC vent back into the air intake (pre turbo/post VAM) or keep the vented to atmosphere set-up? FYI, The oil-separator and PCV on the driver side is the stock set-up with the hose running to the upper intake. At some point, all this will be replaced with a catch can set-up and deletion of the VAM but for now, I'd like to know which would be the best way of going about this. Thanks!
