Can someone give me the part # for the correct tranz vaccum
modulator? I've had my A4LD tranz all redone but I have a shifting issue. Turn the boost under 10 psi and the shifting is all good. But as soon as u turn the boost up near 15 psi or heavy acceleration. The thing either won't shift or u have to lift to make it shift. My guy builds all kinds of performance OD transmissions for newer cars and trucks, but this one has him scratching his head. I'm thinking I have the wrong modulator.
o4 mach-1,white,4at 1 of 169 ,MAC air filter and x-pipe, SCT tune / o9 BMW 328 M-SPORT, white, 6at/ 87 Turbocoupe ,white,4at,KIRBAN afr,GILLIS boost valve,Garrett/SVO T3,cold air,3" STINGER down pipe and tail pipe, DYNOMAX ultra flow stainless muffler, Walbro 255L fuel pump,cleaned and flowed injectors,STINGER BOV, built A4LD trans w/all
4x4 Explorer guts, K245/F57FA torque converter.
TurboBoost88
Nov 2011
Owensboro KY
what year tc ?
86XR7auto
Mar 2003
Mt. Pleasant, MI. USA
TurboBoost88
Nov 2011
Owensboro KY
original ford number for a 1987-1988
e4sz-7a377-a or motorcraft # tm-70.
this is from the last microfiche ford issued, so the part numbers could have been superseded.
hope this helps.
Dan S
Jan 2003
Harrisburg, PA
Several parts houses have the modulator listed as "no longer available". Carquest lists the part under #57-7028 as a cross over to the Ford part number E4AZ-A.
If all else fails email this guy to see if he can help.
[email protected] (Performance Automatics)
TurboBoost88
Nov 2011
Owensboro KY
rockauto has it in stock. part # tm-52, $13.87.
