Crawdaddy
Jul 2003
Knoxville, TN
Searched but couldn't find this. Should there be any vaccum lost from the cruise control because I have a slow vaccum loss coming from it. Checked right at the port going in to the diaphragm after caping all other ports on the controler. Also does the Gillis vavle lose vaccum though the relief port all the time because I also have a slow vaccum loss from it.
86' 5.0/AOD K&N, MSD, Headers
88' TC T-5 Speed pro forged pistons, Lunati turbo cam, Racer Walsh Valves Intake 1.89" SS Exhaust 1.59" SS 1470 Springs 1476A Retainers, PST front and rear, MM Caster/Camber plates, BBK Pressure regulator, Gillis Valve
92' SC stock
95' LX 4.6/AODE stock
The Gillis will lose a small amount of vacuum all the time. That is by design and won't hurt anything.
I can't answer on the speed control.
DonH
Jun 2002
Central Massachusetts, USA
Re cruise control: There shouldn't be a vacuum loss except when the brake is applied. Check the vacuum dump valve at the brake, and the hose to it for leaks
1987 TC stock except ATR 2.5"
Matt S
Mountlake Terrace, WA
When testing just the tube to the server (eliminating everything else) mine also has a slow leak. Every one of them I found in a junk yard did this.
Sold it  *
Crawdaddy
Jul 2003
Knoxville, TN
The vacuum loss is about as fast as the Gillis valve.
The dump valve is not in the picture because I capped all ports off on the control then tried pulling a vacuum.
The slow leak is coming from the diaphragm part of the controller but it seems to slow to be busted so I think Matt is right they all leak a little.
92' SC stock
