Urgent help needed ABS
BLKBRD Offline
Coming home today the "brake" and "Anti-Lock" lights came on.
I was close to home so I popped the hood and have a buzzing sound coming from under the brake fluid reservoir.
There is a black pod (for lack of a better word)
that is hot to the touch and seems to be where the buzing is coming from.
What is it and is that my problem.
And ,, how to fix it if it is.
I am going to disconnect the battery and see if it will reset.
I also don't need a battery drain,,,
Thanks,
`88 Turbo Coupe Blk/Raven 5 spd
`71 Blazer slammed
`62 Impala SS 409/425
`60 Rambler American SW
`56 F-100, sold
--- several HD`s ---
BLKBRD Offline
OK, so the battery disconnect didn't work so I found the plug for that part and unpluged it. Buzz is gone but what now?
What is that part and what does it do?
`71 Blazer slammed
`56 F-100, sold
BLKBRD Offline
OK,, so once again what a great site!!!
I should ALWAYS look in the tech section before panicking!!!
The answer was there,, simple low on fluid,, or so it seems at this point,,
Thanks again for such a great site and tech section !!!!
`71 Blazer slammed
`56 F-100, sold
BLKBRD Offline
Well, It turns out the relay is bad.
Ford part is discontinued and I'm having a hard time finding one.
Any ideas on where to go or a part number from a independent parts house?
Thanks,,,
`71 Blazer slammed
`56 F-100, sold
Look in the Part # forum for after market relays.
Just search on "relay"
1988turbotbird Offline
only thing I can think of would be trying one from a salvage yard and see how it works, or what Pete just said haha
gmaibach Offline
i just got the whole module and everything else for 50 bucks on craigslist... man i love that site the gut also threw in floormats, passenger door panel arm rest, turbocoupe molding badges and a slave cylinder cover for 20 more.
1988 Turbo Coupe 5 speed Red with Red cloth interior, K&N cone filter, Ported IHI turbo, ATR Header ported, Manual Boost Controller at 18 psi.
2013 Focus ST 2.0 Turbo, Buschur green filter, OCD Speed axle back exhaust.
