Urgent Fly Wheel Question... NEED HELP ASAP
Turbosnowbird Offline
My clutch is slipping but I have another flywheel. Can I switch from an aluminium to cast iron? Any differences? Also something is slipping in the drivetrain any ideas. When I put my foot into it the tac jolts up and down and the car jerks. Any ideas? PLEASE HELP!!!
rpratt Offline
Is it snowing out?
Couldn't help it, sorry [Image: frown.gif]
Are you going from an aluminum TO the iron flywheel? either way it will be fine, just resurface the flywheel and get a new clutch, throwout bearing and pressure plate, it will be like new.
Other than the clutch, there isn't anything that can slip in the drivetrain.
If you pull an aluminum Flywheel out of there, you should be able to get some money out of it to help fund the project.
ROn
tps87turbo Offline
You could have a bad rear main seal which would be leaking oil on the clutch disk. That would make it slip.
It doesn't make a difference which flywheel you use as long as it doesn't have any blueing from too much heat or stress cracks. If it needs to be re-surfaced, which I would do when installing a new clutch, make sure that they take as litle off as possible to get it true.
Tony Sceia
Red 88 TC, Med Red with Raven Leather & every option, Walbro 255, 3" SS Downpipe with Magnaflow Dual SS 2.5 Cat Back system, 3-core Radiator, Star Stage 3 Clutch, Rebuilt T-5 Tranny, 4:10 rear, 140 MPH Speedo, New Paint, Headlights, Refinished Snowflakes & New Tires.
She looks so SWEET. Now I need to make some more HP & make the engine look good.
87 Turbocoupe - Bought as a Parts Car, but runs & needs a little work. Looks like we will have HIS & HERS TC's.
Tony Sceia -
HIS Red 88 TC
If the flywheel is cut, be sure to shim it by an amount equal to the thickness removed. If you dont do this, and a fair amount of material is removed, the clutch pedal will engage/disengage too close to the floor, if it disengages at all.
