Been putting in a lot of work to the bird over the last year. Had a really solid winter attacking the to-do's I had been putting off. Redid headliner, new visors, completely stripped and re-did gauge cluster repairing printed circuit board shorts, modified housings for better light spread and put LED's in, also did the tach resistor mod so my converted 302 now reads accurately on the oem 4 cylinder tach
new steering wheel, a little bit of wire re-routing, fixed glass that fell off track and unglued from tabs all repaired now.. Still lots more.
Just acquired what I need to re-adjust the stance for this car. I have wanted to have a meatier tire in the back for a very very long time, grew tired of the non-functional "flush" look that is such a nuisance for speedbumps, ride quality, and since moving into the new house I can barely get it out of the driveway (builder deficiency, that is another topic I could vent for days about... maybe I'll make a post about it just because.)
So I finally bought some larger tires. I had been debating and still do about the wheel choice, I go back and forth between a lot of looks/options out there. 4 Lug will stay, so my options are limited. But I think having the larger tire on the rear will change the look quite a lot of the wheel so I'd like to see. I'm a super budget guy anyways, these tires are by far the best value for what you get (I rarely drive this car, only sunny days so I feel safe with a "budget" tire choice) and the springs were dirt cheap. I researched what I could about having a drop in the rear, but most of what I looked for is obsolete now. The 8599 is listed as a stock spring, but reading the specs on it kind of seems to be very similar to the obsolete M-5300-D. I think these are just taller. I figured for the price totally worth trying out.
The specs of the Moog 8599 springs taken directly from the Moog website:
Free Height 13.33"
Installed Height 9.5"
Inner Diameter 4.01"
Bar Diameter 0.59"
Spring Rate 249(lbs/inch)
Load 926 (lbs)
Moog 8599 Rear Springs $60 shipped
Energy Suspension 4.6101G (Black) rear spring isolators $30 shipped
Achilles ATR Sport 2 $154 shipped for the PAIR
275/40R18
Going in the car on Wednesday! I'm excited to have some tire sidewall give, and actual suspension travel again.. And be able to drive out of the garage fairly worry-free.. So many pro's.
[Image: 29zexih.jpg]
Free Height 13.33"
Bar Diameter 0.59"
Load 926 (lbs)
275/40R18
87 Turbo Coupe
