I posted on here earlier that I always like the 85-86 Mustang orange/red gauges with the orange needles and was wanting to try that for my 88 TC. Well got it all apart thinking I could just change the bulb lenses for the Mustang ones, but both the Tach and the Speedo already have a green overlay built into the gauge itself. So I don't think that would work well with red/orange lighting. But what I did was go ahead and paint the needles with some Testors model paint to match the Autometer gauges I run. What do you all think?
(03-24-2020, 08:32 PM)Kuch Wrote: I posted on here earlier that I always like the 85-86 Mustang orange/red gauges with the orange needles and was wanting to try that for my 88 TC. Well got it all apart thinking I could just change the bulb lenses for the Mustang ones, but both the Tach and the Speedo already have a green overlay built into the gauge itself. So I don't think that would work well with red/orange lighting. But what I did was go ahead and paint the needles with some Testors model paint to match the Autometer gauges I run. What do you all think?
Looks great. Like you always liked the orange/red gauges and the orange/red needles. Had an 80's 280z that had that setup and it was super.
03-27-2020, 12:07 AM (This post was last modified: 03-27-2020, 12:30 AM by JT.)
Did you paint the tops of the speedo and tach needles? When I did this, if I recall correctly, they were transparent with the white on the underside for better illumination. I painted the underside red after scraping the white. That's not the case for the smaller, surrounding gauges.
The picture makes it look like it's painted on both sides but it's actually on the bottom and reflected:
(03-27-2020, 12:07 AM)JT Wrote: Did you paint the tops of the speedo and tach needles? When I did this, if I recall correctly, they were transparent with the white on the underside for better illumination. I painted the underside red after scraping the white. That's not the case for the smaller, surrounding gauges.
Yeah, I just painted the tops of them, I did see the white painted undersides and wasn't sure which way would be better. We'll see how it looks with the lights on when I temp install it to see.
Looks very nice. I need to remove the cluster anyway to check the turbo gauge. I don't have Testors model paint, but I do have acrylic paints from my paintings. The Testors website has different types of model paints. What did you use?
03-27-2020, 01:25 AM (This post was last modified: 03-27-2020, 01:27 AM by Kuch.)
(03-27-2020, 01:08 AM)ABird Wrote: Looks very nice. I need to remove the cluster anyway to check the turbo gauge. I don't have Testors model paint, but I do have acrylic paints from my paintings. The Testors website has different types of model paints. What did you use?
It's Testors Model Master Fluorescent Red (FS28915) enamel. They sell it at Hobby Lobby in the model section. I use it for most of my gauge needle re-paints
