Ok I know I have posted a few times, and my BF and I have figured out the problems with my car before, but this one has us both stumped. We had a problem with an injector bleeding off causing my car in the summer to chug and putter before it would start. So I went out and got the last for freakin OEM ford injectors for that car(took me 3 months for them to find them and close $400 dollars later), well that fixed about a tenth of the problem. They cylender no longer loads up on it but it still chuggs every now and then. We thought well maybe I have a wire going bad. We pulled the wires and they were COOKED, don't buy autolites they suck, It seriously roasted the wires, but my plugs were all normal, so I got Ford Motor Craft wires back on them and motor craft plugs thinking that would solve the problem. Cleaned it up alittle bit. It was pingging so we switched the switch to reg but I'm still running 93 octane in it. Cleaned up the pinging. So the deal is now that when I start the car and its been sitting for atleast 3 hours it fires up first time, it will run alittle rough then start chugging and do this around 200-500 RPMs till it catchs itself..it almost seams like its not firing on all the cylenders..the car shakes, but after about 20 seconds the car itself takes the idle up to about 1500 to 2000rpms and cleans itself up and drops the idle back to around 1k runs fine, except for usually one major miss(as in the car feels like its gonna shut off but catches itself, loses all power for a second then catches itself like it never happened) when I take it out when it's still cold, then once it's warmed up and I start it takes alot of encouragement and giving it gas to make it fire. AND LOL once it's running and warm it has little fluxuations in the idle. Like if I stop at a stop light the idle will bobble ever so slightly. It's got power, it'll still cook tires and boosts just fine. I've replaced every freakin sensor on it, egr, IAC, TPS, my bf thinks maybe my Vane air is messed up..it's the last thing to check. We cleaned the door from sticking, but he's gonna see if he can rip the entire thing apart and clean it all out for a temp fix, cause we are probably gonna convert to mass air this winter. We have run a tester on it and it's not pullin up a single code to even give us an idea. We checked the coil and thinking it wasn't sending enough juice to one of the plugs and its right on the limit as to where it should be. I've replaced the almost every damn thing on the car, and I know its now got 142k on it, but most of the parts are lucky if they have a few thousand on it. I paid 1800 for the car and have put about 4k into it so far and I have quite a few things planned for it before Carlisle next year. You would think the least it could do is run right. If anyone has this problem or knows has to possibly fix my goofed up car I would really appreciate it. LOL or if you can think of something that we didn't think of I mean we are down to either the vane air or the computer is wacked. If you need anymore information about what's wrong with it, I know I don't know as many of the terms I should but I'll do my best to answer or get the answers to help anyone help me. It's been doing this for about 3 months now and I'm just sooooooooo tired of it. Thanks everyone
1988 Turbocoupe
-K&N Cone Filter,3 inch exhaust into a Flow Master Muffler, 3 core Radiator,Remote Starter, ported E6 manifold, and a bunch of little stuff , now I have ROH 17 inch rims and Now we are repainted all black, no door moldings. New carpeting, dashmat, procarparts gauge kit, Alpine 9813 headunit, with xm, 2 Kicker 12" compvr, custom built box, kicker kx 1200 watt amp(max amp is 1346watts), viper front speakers w/tweeters, lol and more I don't remember right now
