uneven pedal issue
BJL Offline
Moderator
have had this issue sinc ei did the 5 spd swap in december 04, but just knwo its tiem i asked about it.
in my 88 TC with facotry 5spd, my clutch and brake pedal are even and the throttel pedal is lower .
after i did the 5spd swap in my gray TC the pedal are differnt, my clutch pedla is normal hieght and my brake and gas are even, i know the brake pedal shoudl be even with the clutch.
do i need to change a rod in the master cylinder to correct this, or fdo i have to deal with it?
im so used to it now, but i afrfriad if someone use smy car they will misintruped the brake pedla hieght, maybe causing an accident, cant have that.
so any suggestions, anybody else run into thtis issue?
it ss 88 TC auto matic converted to 5 spd using all parts from a 83 TC (cable clutch).
thanks !
http://natomessageboard.com/uploads/0000...lsedit.jpg
Brian J Larkin
88TC 320k miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
Ryan H Offline
http://img.photobucket.com/albums/v634/l...%203/3.jpg
^ factory. I think thats just how they're supposed to be... These aren't exactly track cars.
Brian, Are you using a cable clutch setup? If so, maybe???? that has something to do with it. Just guessing here.
40bob Offline
thanks !
I'd say that is the problem. With the adjustability of the cable you might be able to change the "stop" point on the clutch and readjust the cable to account for it.
bob
BJL Offline
Moderator
i guess i can adjust it , but the thing is, all othr cars i get into teh gas pedla is furthest form the driver an dthe clutch and brake are even, does anybody else experiance this or am i relaly just seeing it al in my head?
Brian J Larkin
88TC 320k miles
t-bird88 Offline
Here are a couple of pics that I just snapped. I hope that you can see the depth on mine. I still have the stock hydro clutch set in my TC, but this should give you an idea of what is going on.
http://i25.photobucket.com/albums/c57/t-...s01048.jpg
http://i25.photobucket.com/albums/c57/t-...s01049.jpg
http://i25.photobucket.com/albums/c57/t-...s01050.jpg
Jim B Big Grin .
Gunmetal Grey 88 TC!!!!
Matt S Offline
Yeah that's exactly how mine are after the 5 speed (but hydraulic) setup swap. I'm used to equal pedals. Sometimes my foot is over too much and I catch the brake with my clutch foot.
Sold it Sad*
BJL Offline
Moderator
hmmm, odd, thanks for the replies guys, im knwo im not all "here" but at least i knwo i got soem of me on track now. i wonder if i can etend the brake pedal back??, i bette rnot try to fix somehting that not broekn and then break and have to fix it agian..
thanks agian!
Brian J Larkin
88TC 320k miles
TurboE Offline
It sounds like the clutch cable adjustment is the issue. I did the 5 speed pedal assembly swap by unbolting the auto assembly with the 5-speed assembly, and i would say the clutch and brake are somewhat aligned and the gas pedal is slightly lower (towards the firewall). I used the hydraulic clutch pedal setup.
-88 TC Black
-97 Pathfinder
