tr_guy79
Jan 2004
SE PA (DELCO), USA
Don't feel like buying a full set of 12pt just yet. Need to pull d-shaft.
What size are the bolts on an '88 Auto?
-Shane
Did you check past posts using "drive shaft bolts"
tr_guy79
Jan 2004
SE PA (DELCO), USA
All the search brings up is a post on part numbers, that states "M12x1.75 27mm". I am not well versed in deciphering bolt size designations. I would guess 12, but guessing doesn't get the bolts out when I show up with the wrong size socket...
-Shane
Mike C
Sep 2005
Bellmore, NY
I know that the socket was in my 1/4 inch drive set. Broke it loose with the wrench, but like you I didn't have 12 pt sockets in metric. Space was at a premium also, I don't think the 3/8 drive fit between the shaft and flange??!!?? But there has been a few brain cells under the bridge since last time I did one!
HTH
Mike C
86 5 speed TC black with MS spats and spoiler since 88, 3.73 8.8 since 89. Fresh rebuild at 240K with new Racer Walsh roller cam, 88 hood. All 3" exhaust w/3" performance cat. 13" Cobra brakes,SFC, Max/Motorsport C/C plates,adjustable lower control arms w/ double adjustable uppers. Konis & Eibachs.
tr_guy79
Jan 2004
SE PA (DELCO), USA
Turned out to be 12MM. Used a box wrench with a pipe. Bent the wrench up, but they came out.
Thanks
russ c
Nov 2005
Mt. Olive,NC
Snap-on part # S6160 specially designed 1/2" drive 12MM 12pt. impact socket for use on Ford drive shafts.
86TC Saved from certain death
88TC Gave its life so other TCs could live.
88TC DD.
