Twin Turbo
Noname
Guest
Has anyone ever tried buliding a torbo coupe with twin turbos. Is it possible?
lmp320 Offline
i don't think it is possible, but due to the vastness of people with too much money and time, i wouldn't rule it out.
shiftless Offline
one question- WHY?
GaryS#2 Offline
Well I think the main reason is reduced or no lag.
Toyota did it and some other cars too.
Sequential turbos. 1 small and 1 big.
Grocery Getter/Rice Cooker.
**PathogeN** Offline
Sequential turbos are certainly possible with enough money...but theres basically no need. Sequential turbos are pretty much a thing of the past with modern turbo technology. Like porsche for example, theres no more sequential twins like the 959 etc. just a matched pair like current 911 turbo. Staged turbos have been done on tractor pulling stuff, but for street more than one just isn't needed...you'll end up breaking parts long before a very large turbo will run outta wind these days.
1987 TC 5-Speed Red/Red Leather | 5.0 Mustang T-5, FRPP Cobra Clutch, Esslinger Aluminum Flywheel | FRPP Valve Springs & Hardened Valves | Walbro 255LPH Fuel Pump | Gutted Upper, Knifed Lower, Knifed TB | Gillis @ 18 psi, Bosch Bypass Valve | K&N Cone, VAM Mod | ETS Timing & Accessory Tensioners, Unorthodox Pulleys | No cat, ETS 3" DP, Dual 2.5" Dynomax | IHI w/Teflon Impeller | 2 Piston Brembo Brake System & 4-Channel ABS Piggyback Chip | HPM Rear Lower Control Arms, Griggs Front A-Arm Kit & Lightened K-Member | Eibach Pro Kit Springs | KYB AGX Adjustable Struts, Tokico Shocks, Koni Quads | Max. Motorsports Caster/Camber Plates | PST Polygraphite Bushings | Lincoln LSC Front Sway bar | Rewound Ford P.I. Alt, 185 Amps | 2000W Infinity/Clarion Pro Audio IASCA Competition Audio System
88 Turbo Coupe (White)
88 Psudo Coupe (Silver LX)
KMcGrathNJ Offline
found on the web:
Know what else? You won't likely ever see a serial multi-staged turbo system (with its attendant intercoolers) in a passenger car. These systems are typically used when boost pressures in excess of 60 PSI are required, such as in farm machinery, power generating plants, and dragsters.
Kevin
88 TC man. tran. White/Burgandy All options exept Leather and spoiler; K&N cone filter; Blaupunkt H/U; Boston Accoustic 3 1/2" in dash; Polk 6" in doors.
Near Future - Gillis boost control; High flow cat, 3" straight thru.
88 TC Auto putting on a few band aids to make daily driver so I can work on other TC.
Kevin
88 TC T5;White/Red; All options exept Leather; Front Mounted K&N cone filter; 140 Speedo; Superchip; Gillis Boost Valve; Custom vac/boost-volt-temp gauge cluster in console Ground Effects; Spoiler; Blaupunkt H/U; Boston Accoustic 3 1/2" in dash; Polk 6" in doors; Infinity 5 1/4 component in rear deck;
Rockford 10" sub; (2) Alpine amps
Near Future -Paint
