boosted85
Sep 2008
Omaha NE
But hazards work replaced flashers still nothing
Complete custom downpipe to tail pipe 3in exhaust, ranger cam, cran double valve springs, stock dsm bov switchin out for a good aftermarket, cone filter, fmi 2.5in piping, walbro 342hp, aeromotive fpr, fuel pressure 45 base, 17in cobra R's, steel braided oil feed line, 96lb injectors, megasquirt 1 v2.2, msd blaster 2 coil 86 t3 48, innovative lc1 wideband,
Probably the MFS. Common Ford problem. Time to break out the wiring diagrams and a DMM and start doing some troubleshooting.
boosted85
Sep 2008
Omaha NE
The wat
boosted85
Sep 2008
Omaha NE
The wat
MFS = multi function switch - on the steering column
DMM - digital multi meter - a volt/ohm tester meter
They go bad all the time!!!! Just might be the trouble
boosted85
Sep 2008
Omaha NE
Wat do I do lol
50RACER
Jan 2010
Manassas, VA
Seriously, you guys need to post a glossary for all the abreviated terms that you use! I'm with boosted!
87 TC Medium Canyon Red
88 TC Black Beauty
Kev
Harrison Arkansas
Kev
I would check that all your bulbs are still good. When a bulb goes out in the tail light, the blinkers won't work. Happens to my bird almost every time I go to the car wash instead of washing it by hand. Water gets in on the hot bulb and breaks it, then the blinker quits. Yep, check those bulbs.
Kev
1988 TC 5spd
Limited list here:
http://www.turbotbird.com/faqs/#Acronyms...reviations
The following list was compiled by Turbo Ray and the users at Turbo Ford. It's posted somewhere there but the link at the bottom is probably broken. It is possible to copy and past this into a text document on your hard drive for future reference.
Quote:Here's what I've compiled so far (from my orig list + MOST of your additions). Note that not all are 2.3T specific, but are commonly used on this forum:
NOTE: If not listed below, see Common Internet Acronyms
ACT = Air Charge Temperature (sensor).
AFPR = Adjustable Fuel Pressure Regulator.
AFR = Air/Fuel Ratio.
AOD = Automatic OverDrive (trans), not OEM on T/F's.
ATDC = After Top Dead Center (crank position).
A/R = Area Radius ("size" of turbine/exh hsg).
AWIC = Air-to-Water InterCooler.
A4LD = Auto 4spd Lockup-converter Drive trans (87-up T/F's).
BPS = Barometric Pressure Sensor.
BCS = Boost-Control Solenoid.
BOO = Brake On-Off (signal to EEC).
BOV = Blow-Off Valve (vents boost to atmosphere upon decel).
BPV = By-Pass Valve (recirc's boost to turbo inlet upon decel).
BTDC = Before Top Dead Center (crank position).
CAI = Cold Air Intake.
CC = Cubic Centimeter(s).
CEL = Check Engine Light (aka MIL), indicates EEC-syst prob.
CFI = Central Fuel Injection (aka TBI).
CFM = Cubic Feet per Minute.
CHRA = Center Housing Rotating Assembly (center section).
CID = Cubic Inch Displacement.
CM = CentiMeter(s).
CO = Carbon Monoxide (exh/smog component, measured in %).
COP = Coil On Plug (individual ign coil on each sp/plug).
CO2 = Carbon Dioxide (exh/smog component, measured in %).
CPS = Crank (or, Cam) Position Sensor.
CPU = Central Processor Unit (computer).
C/R = Compression Ratio.
DIS = Distributorless Ignition System.
DOHC = Dual OverHead Cam.
DOL = Data Output Link (EEC to trip minder, only late TC's).
DP = Down Pipe.
DPH = Dual-Plug Head.
DS = Drive Shaft.
DTC = Diagnostic Trouble Code.
ECT = Engine Coolant Temperature (sensor).
ECU = Engine Control Unit (computer).
EEC = Electronic Engine Control.
EEC-IV = Electronic Eng Control, 4th-generation.
EFI = Electronic Fuel Injection.
EGO = Exhaust Gas Oxygen (sensor).
EGR = Exhaust Gas Recirculation (smog device).
EGT = Exhaust Gas Temperature.
EMS = Engine Management System.
ET = Elapsed Time.
EWG = External Waste Gate.
FMIC = Front-Mounted InterCooler.
FMU = Fuel Management Unit (aka, rising-rate FPR).
FPR = Fuel Pressure Regulator.
GPH = Gallons Per Hour (liquid flow measurement).
GPM = Gallons Per Minute.
HC = HydroCarbon (exh/smog component, measured in ppm).
H/G = Head Gasket.
HLA = Hydraulic Lash Adjuster ("lifter").
HSC = High Swirl Comb. (Tempo, etc - pushrod 2.3, not a T/F).
IAB = Idle Air Bypass (valve/solenoid, aka IAC/ISC).
IAC = Idle Air Control (valve/solenoid, aka ISC/IAB).
IC = InterCooler.
ID = Inside Diameter.
IDM = Ignition Diagnostic Monitor (EEC circuit).
IHI = Ishikawajima-Harima Ind ("small" OEM T/F turbo, 87-89).
IRCM = Integrated Relay Control Module (87-up TF's).
ISC = Idle Speed Controller (aka IAB/IAC).
J/Y = Junk Yard.
KAPWR = Keep Alive PoWeR (12V to EEC "memory", not switched).
KM = KiloMeter(s).
KOEO = Key On Engine Off (EEC self-test mode).
KOER = Key On Engine Running (EEC self-test mode).
KS = Knock Sensor.
LCA = Lower Control Arm (suspension component).
LCA = Lobe Centerline Angle (cam positioning term).
LPH = Liters Per Hour (liquid flow measurement).
LSA = Lobe Separation Angle (between int & exh lobes).
LSD = Limited Slip Differential.
MAF = Mass Air Flow (meter, or eng-mgt system).
MAP = Manifold Absolute Pressure (sensor).
MCU = Microprocessor Control Unit (computer).
MIL = Malfunction Indicator Light (aka CEL), ind's EEC-syst prob.
MLS = Multiple Layer Steel (head gasket), i.e. Mr gasket #3180G.
MM = MilliMeter(s).
MPI = Multi-Port Inj (sequential or batch/gang-fired).
N/A = Normally Aspirated.
NHRA = Nat'l Hot Rod Assoc (Dominant drag-racing organization).
NOS = Nitrous Oxide Systems (brand name), or New Old Stock.
NOX = OXides of Nitrogen (exh/smog component, measured in %)
NPR = Isuzu "NPR" box-truck intercooler (large & small).
NPT = National Pipe Thread.
N2O = Nitrous (2 parts nitrogen) Oxide (1 part oxygen).
OBD-I = OnBoard Diagnostic system, 1st-gen (80-95).
OBD-II = OnBoard Diagnostic system, 2nd gen (96-up).
OE = Original Equipment.
OEM = Original Equipment Manufacturer.
OD = Outside Diameter.
OHC = OverHead Cam.
02 = Oxygen (sensor).
PCM = Powertrain Control Module (computer).
PCV = Positive Crankcase Ventilation (valve/system).
PIP = Profile Ignition Pickup (Hall-Effect ignition trigger).
P/N = Part Number.
PPH = Pounds Per Hour (liquid flow measurement).
PPM = Parts Per Million (measurement, i.e. = HC emissions).
PSI = Pounds per Square Inch (boost, fuel, etc).
PW = Pulse Width (time inj's are open in MS/miliseconds).
RPM = Revolutions Per Minute.
SC = Super Coupe (factory-s/charged T/Bird).
S/C = Super Charger.
SD = Speed Density (eng-mgt system).
SEFI = Sequential Electronic Fuel Injection.
SEMA = Specialty Equipment Manufacturers Association.
SFI = SEMA Found., Inc (sets safety stds for hipo/race equip).
SHO = Super High Output (model of DOHC Taurus).
SOHC = Single OverHead Cam.
SPOUT = SPark OUTput connector (remove to set timing).
SROD = Single Rail OverDrive (early 4 spd trans).
S/S = Stainless Steel.
STI = Self-Test Input (EEC circuit).
STO = Self-Test Output (EEC circuit).
SVO = Special Vehicle Operations (also, 84-86 Mustang model).
TB = Throttle Body.
TBI = Throttle Body Injection (aka CFI).
TC = Turbo Coupe.
TCA = Tubular Control Arm (suspension component).
TDC = Top Dead Center (crank position).
TFI = Thick Film Ignition (module).
T/F = Turbo Ford (factory-turboed Ford, Mercury or Merkur).
TPS = Throttle Position Sensor.
TSB = Technical Service Bulletin.
TVS = Temperature-controlled Vacuum Switch.
UCA = Upper Control Arm (suspension component).
VAF = Vane Air Flow (meter).
VAM = Vane Air Meter.
VAT = Vane Air Temperature (sensor).
VE = Volumetric Efficiency (air consumption÷displacement).
VREF = Voltage REFerence (regulated voltage to sensors).
VSS = Vehicle Speed Sensor.
WBO2 = Wide Band Oxygen (sensor).
WG = Waste Gate.
WGA = Waste Gate Actuator (WG servo/canister).
WOT = Wide Open Throttle.
Anni = Anniversary edition.
Baro = Barometric pressure (sensor).
Cat = Catalytic converter.
C3 = 3-spd light-duty auto trans (79-86 T/F's).
C4 = 3-spd moderate-h/duty auto trans (69-up).
Dizzy = Distributor.
Duraspark = Magnetic-triggered Ford ignition (74-82).
E3 = (abbr) Early crack-prone 2.3 turbo exh man (83-85).
E6 = (abbr) Late 2.3 turbo exh man (86-89).
Flow = Flowmaster chambered muffler (brand name).
Lambda = (sensor), aka oxygen sensor.
LA3, PE (+ many others) = "Catch Codes" for 2.3T ECU's.
Lima = Family of Ford engs orig-made in Lima, Ohio (incl 2.3).
Merk = Merkur XR4Ti.
Sig Rtn = Signal Return (EEC circuit, similar to ground).
Stage II, III, IV, etc = Sizes of turbine (exh) wheels/impellers.
Stoich = Stoichiometric (14.7:1 "ideal" AFR at idle/light cruise).
Two/2-Step = Two-stage rev limiter, low limit is switch-activated.
T3 = Model of Garrett/AiResearch Turbo ("larger" OEM T/F, 79-86).
T3/T4 = "Hybrid" turbo made with T3 turbine & T4 compressor.
T-5 = Borg Warner 5 spd used in Ford/Mercury T/F's.
T-9 = Borg Warner 5 spd used in Merkurs & Scorpios.
XR7 = (Cougar model) Mercury's version of the TC.
1035 = part number of FelPro heavy duty head gasket.
46, 50, 57, P(etc)-trim = Sizes of compressor wheels/impellers.
Compiled by Turbo Ray from Turbo Ford, 3-27-04
http://www.turboford.org/cgi-bin/ultimat...210#000000
