Turn signalon and side markers light up
RDOG Offline
when i turn on my turn signals my side markers also light up. Is this normal or some kind of electrical problem?
That the way they are suppose to work. Nothing is wrong.
and jack rails.
BCA Offline
RDOG,
Sounds like what your referring to are the "cornering lamps" (if your car has this option) which are located in each fender just in front the wheel.
These clear lamps should come on with the corresponding turn signal, and both sides should light up when you turn your hazard lights on.
Brent Abrams
1985 Cougar XR-7 5-speed
1986 ASC/McLaren Coupe
1971 Ranchero
Hi-Jumper Sandrail w/2.3 Turbo Power
1971 Ranchero GT
tylerport Offline
The Cornering Lamps were designed to illuminate the side of the road toward where you were turning.
Jim Portteus
86 Turbo Coupe, 128K Miles, 140MPH Speedo, Gillis Valve, 2 1/2" Downpipe to 2" Duals w/ 12" Glasspacks, 245/50R16's and new paint.
Jim Portteus
