turbo water hoses
Ricky03 Offline
Where can I get the red waterline hoses that connect the turbo waterlines on a 88 TC ? The two that are about 1/4" and 4" long. Can't seam to find any around here.
turbotbirdguy79 Offline
I think I found my hose by searching on here.
tps87turbo Offline
They are discontinues from Ford. You can try Napa to see if they have any Hi-Temp water hoses.
Tony Sceia -
HIS Red 88 TC
NAPA carries some hi temp hose. But I don't know if they carry it in that small a diameter for the supply side on an IHI
ERIC J snowbird Offline
Mike has them.
http://natomessageboard.com/cgi-bin/ulti...2;t=000022
- ERIC J
87 Black 5speed, 88 Black 5speed.
glenn-tc88 Offline
my measurement is 5/16? nobody listed what size they used?
Glenn Dembowski
2003 Mercury Marauder Black
1988 Thunderbird TC Sandalwood 5sp
1974 Harley Davidson FLH
1998 Chevrolet K1500
5/16" sounds about right. I bought a few feet of high temp Silicone hose from Ebay almost 20 years / 100+K miles ago. Been working fine ever since.
glenn-tc88 Offline
Jeff K Wrote:5/16" sounds about right. I bought a few feet of high temp Silicone hose from Ebay almost 20 years / 100+K miles ago. Been working fine ever since.
thank you jeff
Glenn Dembowski
fred k Offline
(01-30-2006, 10:53 PM)Ricky03 Wrote: Where can I get the red waterline hosesĀ  that connect the turbo waterlines on a 88 TC ? The two that are about 1/4" and 4" long. Can't seam to find any around here.
hps-siliconehoses except these are either black or blue
http://www.hps-siliconehoses.com/hps-8mm-silicone-tube-tubing-coupler-3-feet-coolant-tube-hose-4-ply-blue.html
fred l kennedy
