Turbo To Exhaust Manifold Gasket
Ford part # E3ZZ-9450-A gasket, comes in a pkg. of two. This is a metal gasket that goes between the turbo and the manifold. Hope this helps.
Provided by Turbojet
rudbech Offline
I didn't think that gasket was necessary. -heard of people just using...was it some sort of copperpaste?
88 Thunderbird TC
88 Thunderbird V8
90 Volkswagen Golf
88 Thunderbird TC
88 Thunderbird V8
90 Volkswagen Golf
rv23tc Offline
you can buy the whole gasket kit at any advance auto parts store
mods: 260 armstrong xp pump,430gears,,boost controller,9mm motorsport wires
mods: 260 armstrong xp pump,430gears,,boost controller,FPR,9mm motorsport wires,K&N filter
I put the Felpro Turbocharger Mounting (gasket) Set in a seperate post to this forum
86 XR7 5spd Offline
the turbo dodges (TDs) which use the same T3 turbo and same size and shape turbo mounting flange (albeit with a different bolt pattern) do not have a gasket here - neither from the factory nor do the regular TD guys use one
the TD's rely on ABSOLUTELY flat mounting surfaces on both the exh mani and the turbo turbine housing flange for effective sealing
THEN a medium thick film of regular wheel bearing grease is applied to one surface
RESIST the urge to overtighten the turbo <-> exh mani nuts as this will warp the flange a smidge creating a leak - DAMHIK
this is the normal protocol for 1000's of hard running TD's - including my 13.7 second omni
I usually use a Big floor mounted belt/disc sander to resurface the flanges (using the belt part); when I did my E3 I paid $25 for a local machine shop to do teh same thing
David T
2.5" exhaust w/ cherry bomb
