Resurectedbird
Jul 2003
York, PA
I have noticed that turbo timers are not discussed on here, where imports use them all the time.
Who has them? I have one, but haven't hooked it up yet. It seems to me to be one of the best investments for your turbo life.
Whoever has one-do you have any diagrams of how you hooked it up? Mine is the Apexi and does not offer the pigtail to tap into the system easily, need to cut and splice
Currently birdless, but will get another someday!
Why dont most of us use them? My guess is we are all a bunch of cheap bastards who would rather spend the $$ we have on something to make the car go faster or look better! [Image: smile.gif]
I see one big problem with the timers on a stick shift car. You must leave the car in neutral with only the parking brake holding the car in place. Park brakes can fail.... rusted calbes snap, etc. Happened to me twice in the last 20 years. Once, the car rolled down into a ditch. What a mess. Personally, I will not park a stick shift car anywhere without setting the park brake and putting it in gear.
IMO, you only need to let the car idle down for a few minutes before shutdown if you have been just boosting the hell out of it. If you have been driving normally for at least a few minutes, just shut it off. Also, many of us run synthetic oils, which is MUCH more resistant to coking, etc. than regular dyno oil.
