turbotbirdguy79
Feb 2004
lockport,ill,united states
I just got a price on how much its is gonna cost to have my t3 rebuilt,the guy told me 435.00,everything brand new.Does that sound fair?Its a 48/60 and hes putting on a svo housing also.I see crap turbos all day on ebay cheaper than that but I learned a long time ago you get what you pay for.The guy said the reason my turbo went out was because of oil contamination (blown head gaskets).Thanks again!
1988 Tc,SC50(.63),Bosch BPV,Coolingmist methanol injection activated at 10 psi,FMS big valve 1.89/1.59 head,a234,ported E6,ported lower and upper intake,Gillis,3"downpipe,3"exaust,Kirbin AFPR,255 HP LPH pump,Racer Walsh adj cam pully 2* advanced*,K&N cone,MSD Blaster,autolite 103 plugs,T5 swap,3.73s,shifter,Centerforce stage 2 clutch,motorcraft tuneup.
Qwertys
Mar 2004
California
that sounds pretty expensive for a rebuild.
for 200$ more you can get a brand new T3.
if hes saying everything brand new, then hes lieing if its a rebuild. with a rebuild, its likely the wheels and shafts are ok, sounds like the CHRA and bearing is bad. I've never heard of oil contamination though. sure it can get baked on if a seal is bad but olmost the whole CHRA has oil running through it and if theres any on the wheels you should be able to just take them out and clean them.
and you're right, you get what you pay for.
'85 TC BPV and Ford FMIC
'88 TC Kirban AFPR, Autometer Boost, FP and A/R Gauge, 8.8 to 4.10 rear, Walboro 255lph Fuel pump, Garrett GT3071R T3/T4 Dual Ball bearing Turbo, Custom AWIC.
Not cheap but not real far out of line considering a housing change is in the package. I would find out exactly what new parts, like shaft or wheels, is included in the quote.
Oil contamination is not unheard of. I had a rebuilt go after only 5K miles. I let the place that did the rebuild do an autopsy. They said some kind of fine particles went through it. That was the time I had bought a new oil supply line. but I screwed it up so I ended up putting the old line back on. Since the old line has been off the car a long time, it had dried out on the inside. When reinstallled all the accumulated dried oil varnish came loose and plugged up the oil passages in the turbo. Ergo why many turbo shops will not guarentee a new or rebuilt turbo unless a new supply line is used.
turbotbirdguy79
Feb 2004
Both fins were demolished very badly,on the cold side there was really nothing left,I never looked at the hot side.The turbo was used though so I dont know if the previous owner did oil changes,let the turbo cool after hard boosting,I did though.I took care of the detonation probs(leaking trans module)The guy also asked me if I ever overboosted it,I told him I had my gillis set at 21 psi and when i was at full boost it was for a very short time,he looked kinda shocked and said "you got 21 psi out of this?".Is that to much for a t3?I dont think thats too much.thanks again!
turbotbirdguy79
Feb 2004
The oil line is also brand new,earls braided line works great too.
Qwertys
Mar 2004
California
21psi is nearing the T3's efficiency, but it should be no problem for the turbo, your engine and intercooler is a different story.
since you are replacing the housing, is it the hot side? i have a .63 T3 turbine housing i will never use and i will sell it cheap if you want it (its in great shape)
i also have the compressor housing. all you would need is a good CHRA and shaft. i could even throw in the extra bolts, ect that i have left from my rebuild kit for a bit more.
motormenace
Jun 2001
Timonium, MD
if your going to run 21 psi, i highly recomend running a .63 housing. with the .48 you are going to blow more head gaskets do to heat and the lack of air flow.
86 turbo coupe (14.12 at 15 psi. sleeper) *gone*
...so you have a V8...isn't that cute...
turbotbirdguy79
Feb 2004
Im still running the stock intercooler in the stock place.Im planning on mounting it up front when I get the time.Ive been looking in the boneyards for a mitsubishi conquest/starion intercooler but no luck.I used too have one,It came off my brothers car which I think all conqusets are cursed so I sold it(the kid put it on his eclipse and got tboned the same day he put it on.thanks again
charles88tc
Nov 2004
dahlonega ga us
I purchased a brand new IHI from East coast turbo in North Carolina for $425 give em a shout
88 tc 5sp, Gillis, K&N on vam, Redneck cat back exaust (nothing from the cat back) 220,000 mile short block. Rebuilt 86 head and cam.
jmthunderbirdturbo
Feb 2005
Ostrander, Ohio
im in central florida, and discount auto sells a t3 turbo for an 86 tc for 349.99.. i ordered one just to see if it was true, then never picked it up.. i looket at it though..it was all shiny and stuff.. [Image: biggrin.gif]
if u want one, check out good old discount...
