Turbo on Tbird LS 5.0
whiteacid Offline
Hey, I have a 88 LS 5.0 and I was wanting to put a turbo on it. I wanted to know if it was possible if I could do that and if it was would it be possible to have 2 of them on it? Ive seen many imports w/ dual turbos on them and was wondering if I could do the same to mine with the T/C's turbo? If so could someone tell me what steps i would need to do to get it done right. Thank you
thesandman144 Offline
you can get someone to fabricate the headers (go to red headers to get an idea of what you got to do) you can get two turbos from the junk yard from any turbo coupe with the matching intercoolers mount the coolers in the front and the get someone to fabricate the a 3 inch downpipe exhaust you probably gonna have to cut into the fire wall to get the down pipes to fit just my two cents but i think it would be cheaper just to get a supercharger ive thought of the idea myself it could work but the expense was not worht it
(nato member) comletely rebuilt suspension with additon of caster camber plates lowered with mustang springs painted candy royal blue next up is increase of horse power by any means possable, (second place is just the first loser)
whiteacid Offline
How much would it cost, to do what all I want to do?
duanetc Offline
if you are somewhat inclined mechanically then 800-1200 depending on the price of the turbo's
t3/t4 ball bearing hybrid spearco intercooler. Ported big valve head, 44pph injectors,motorsport cam and roller followers kirban afpr walbro 255lph fuel pump 65mm tb atrp downpipe extrude honed intakes and a ported e6 atr external wastegate greddy bov prolly some stuff I missed too
well for starters a pair of 3 inch down pipes run for about 120 each then red header will charge you about 1000 for a pair of headers the two turbos with intercoolers about 300 to 500 with all the hoses and brackets then the exhaust another 300 so you figure about 2000 estimate maybe cheaper
Allan S Offline
It costs around $10k to have a 5.0 twin turbo setup professionally done on a Mustang. If you get good at it you could make it a profitable hobby. [Image: smile.gif]
SCMC Marketing Director
www.svtcobraclub.com
2004 Redfire SVT Cobra
87 TC RIP 10/2003.
whiteacid Offline
Money isnt really and issue. I just figured I would learn more if I rebuilt some old crap and did it all myself. Bt 10k, might take be a lil while to get but i will surly get it =]. I just want to be able to talk junk and back it up =]. Plus i want to run for titles down at the local drag strip. Hopefully I will do good.
Retorical Offline
Twin turbo T-bird at http://www.geocities.com/MotorCity/Downs...dgetTT.htm
This guy did an awesome job!
46Tbird Offline
This is a local guy - with a famous car. [Image: smile.gif]
Twin-turbo 302 in a Fairmont. The shortblock and turbos are straight from TCs. With no intercooler, carbed, and cast iron Windsor Jrs, he has run a best (so far) of 9.86/138. [Image: biggrin.gif] You ought to see his other Fairmont - the one he's building for his wife. That is gonna be the fast one. [Image: wink.gif]
http://www.geocities.com/MotorCity/Speed...split.html
[This message has been edited by 46Tbird (edited 04-09-2002).]
Jeff K Online
Just be aware that the 5.0 SO motor in the Tbirds / Cougars have cast pistons, so I wouldnt go too high on the boost unless you switch to HO forged pistons.
