Harvs
Jun 2002
Ware, MA
Ok, Im only running 15 to 16 pounds, and i just did a tune up with plugs, wires fuel filter,ect. Most of the time when i step on the gas the car hesitates at full boost,or it will pull real hard and fall off at full boost, and it will buck every now and then at high psi, it will go, but be sluggish. All the lines are tight.
Did you check the ignition timing?
Glenn 88TC
Lebanon, PA
Check your fuel pressure under boost. I bet the stock fuel pump is falling off.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, TE60 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Hallman boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
Harvs
Jun 2002
Ware, MA
No i didn't check my ignition timing, but i'll do that, and How do i check the fuel pressure without a gauge?
Quote:How do i check the fuel pressure without a gauge?
You don't. You need a gauge that screws onto the scharder valve on the fuel rail and can be extended to the windshield so you can see it while test driving. See if you can borrow one from somebody.
Joe F
Jul 2002
Hawkins, Texas - USA
Or get one from Autozone; mine was about $30
Joe F.
See my 87 TC page for my list of mods & upgrades
