Lx-tasy
Jun 2004
Jacksonville, FL
I have a t-3, how do I tell what size it is?
Thanks,
Chris
SteveX82
Toms River, New Jersey
Read the numbers printed on the compressor housing and inside the turbine inlet.
Lx-tasy
Jun 2004
Jacksonville, FL
Ok, here is what I have.On the Red Reman tag there is an S/N GHM05699 and a P/N 409174-9054 Then on the hot side down by where it bolts to the manifold it says AR 48
Is this better then my IHI?
Thanks,
Chris
All stock Ford T3 were 60 AR on the compressor side and either .48 or .63 on the hot side.
Is it better than your IHI?: it will push more air than the IHI at a given psi level and it will allow you to run a little more psi. I don't know if that is better or not [Image: biggrin.gif]
oldraven
Aug 2002
edmonton, alberta, canada
Your IHI is way better. You don't need to go any higher than 4500rpm anyway. Just send me the T3 and I'll dispose of it for you. [Image: wink.gif]
