ABird
Mar 2011
Myerstown, PA
What is the best way to check the turbo gauge in the dash? Mine does not register at all. I'm pretty sure the turbo works, I can feel it boost. I pulled the dash cluster out far enough to make sure the hose was connected. The hose felt fine, no dry rot. All the other gauges work. Thanks
AES
Mikey97D
Jan 2018
CONNECTICUT
You can disconnect the small line off the vacuum tree and if you have something to control air pressure test it that way.
Kuch
Sep 2016
Manlius, NY USA
Like Mike said, the line that connects to the vac tree is very small, looks like 1/8" line and connects to the tree via a rubber adapter.
ABird
Mar 2011
Myerstown, PA
Kuch
Sep 2016
Manlius, NY USA
Awesome, I love it when a plan comes together!
Mikey97D
Jan 2018
CONNECTICUT
That'll do it! Glad you found the problem.
