trashline
Feb 2005
Levittown, PA
where the heck can I get class 10.9 bolts for my elbow? Ive tried every napa and hardware store in the area. I sent an email to Charlie at evergreen to see if he can get me a couple.
Thndrchckn420
Mar 2003
Winchester, VA
Got mine at ACE Hardware.
88 5-spd. Precision SC-50 ball bearing turbo, gillis, full 3" exhaust w/ 3- 1/2 crome tip, ported E-6, ported big exhaust valve head, ranger roller cam, Essy cam gear, K&N cone in front of the radiator, gutted upper, knife edged lower, Walbro 255HP pump, Kirban AFPR, Forge BPV, PA Performance 130 AMP Alt...
trashline
Feb 2005
Levittown, PA
Ace was the first place I looked they had 10.8 but they were really long. and I asked
how about the use of studs?
Cut them to length with a dremel and cut off wheels
trashline
Feb 2005
Levittown, PA
Pete they are like 4 inches long but they have threads on only half the bolt. there not fully threaded
Thndrchckn420
Mar 2003
Winchester, VA
Ouch! So close. Your talking about the short ones that hold the elbow to the turbine housing? I can try to find them and send you some if youd like. Our Ace is like a super Ace.
Quote:they are like 4 inches long but they have threads on only half the bolt.
Opps, that won't get it at all.
I have them in class 12.9, but they are 30mm long, so you'd have to cut about 1/4" or so off of them..
trashline
Feb 2005
Levittown, PA
god I called all three local machine shops, and two grainger, this is nuts. Bob I will be sending you an email
Joe F
Jul 2002
Hawkins, Texas - USA
You might try McMaster-Carr online. www.mcmaster.com
Real good place for hard-to-find hardware.
