Turbo deaths ???
4EyedTurd Offline
Well, its only been a while since I got into the turbo4 scene but the only thing I've heard about them is they are prone to fire deaths. Why is this??Whats the culprit? Just curious since I'm got a fuel smell going down the highway today.
Quote: but the only thing I've heard about them is they are prone to fire deaths.
I tend to doubt these are any more fire prone than any other 16-20 year old FI car. Unless you got a K&N cone filter and didn't hook the charcoal canister line back into the intake system, you should not get a gas smell. You need to investigate this quick. Could be as simple as an injector O ring dried out and needs changed. Those are fairly easy to change Sometimes the injectors develop leaks and need to be replaced.
See this post: http://natomessageboard.com/Forum1/HTML/012600.html
Joe F Offline
IMHO the rep for "fire deaths" probably comes from the burning alternator syndrome, which AFAIK is not confined to turbo 4's. It's related to Fords failed "alternator output plug" experiment (my words). About the gas smell - find and fix it quick! Mine was traced to leaking injectors.
HTH.
Be Cool,
Joe
JR's Place - My 87 TC
Mr. Vanos Offline
I had an alternator plug fire on my '85. Thankfully I caught it just as it was starting and was just burning the plastic on the connector. I cut out the connector and resoldered the wires together and everything was fine after that. That car had 175,000 miles on it when I got rid of it (with rebuild at 124,000 due to burst coolant line).
I carry a fire extinguisher in all my cars, but have yet to have to use them. Very cheap insurance.
GlassRooster Offline
I had a strong gas smell too. It was 2 injectors leaking and pooling the gas on the lower intake. I disregarded the pool as oil off of the valve cover since it looked black. I put a paper towel in it to clean the "oil" up and pulled it out. It was all 95% gas and a little oil. So look till you find it. I was lucky i wasnt invited to my own Car-B-Que.
David
87 TC Faded Burgundy with faded red interior
K&N and cold air ducting- rest is bone stock
02 Mazda Protege 5 Replaced Dead Saturn
99 Cougar- Wife's car new body style now Discontinued.
Dick Murphy Offline
I just went through the fuel smell scenario. Ended up being injectors that needed replacing. PITA to seal them then discover that that doesn't fix it. If you can afford the parts and are sure it isn't the fuel rail leaking just replace the injectors.
88 TC
86 XR7
91 Mustang LX with 85 XR7 motor
77 Lotus Esprit
87 Mercedes 190
66 Mustang
I wonder why my wife thinks I have too many cars??
88 TC
77 Lotus Esprit
87 Mercedes 190
91 Mercedes SL 300
66 Mustang
Dick Murphy Offline
There is a several item post regarding this item within the last few days under the topic "fuel leak."
88 TC
77 Lotus Esprit
87 Mercedes 190
91 Mercedes SL 300
66 Mustang
crystal Offline
Mine caught fire last week and it's alive and kicking again (valve cover blew, puked oil on to turbo which ignited the oil)
Guess who's buying fire extinguishers and urging all her friends to [Image: wink.gif]
88 TC, 63 Ranchero, most of a 48 Prefect Wink
tlswart Offline
When you get a fire extenguisher, make sure that it is all metal. Do not buy the cheap plastic valve one from WallyWorld. If you want to have one you want to know it will work and that you can refill it. Have them checked by the pros every 3 to 5 years. Check them for proper charge (green) every time you open the trunk or see a wrecked car on the side of the road.
I was standing by and watched a car fire with my small extinguisher in hand to stop grass fires until the big guys got there. To late to do anything else. Saved one car years back, not mine. That guy thought the world of me.
One in every car, smalls. Two in garage, one large and one medium. One in utility room, medium. One in kitchen, medium. One in office, medium. One next to bed, medium.
Paranoid? DUH!!!!
Obsess much? DUH!!!
Terry: 88TC, 5spd, Gillis valve.
[This message has been edited by tlswart (edited 11-19-2004).]
