Turbo coupe wheels
Prophet82 Offline
Hi guys I just purchased a set of turbo coupe wheels for my 5.0 87 t-bird and my friend Jason said you guys could tell me how I could remove the clear coat with some special removing agent. I would like to how much it costs and where I can purchase it
thanks Matt
Dan E Offline
It's called Aircraft Remover. You can get it at any Auto Parts or Hardware Store. It's fairly cheap.
Usually takes a few coats. Try sanding first so it penetrates the clearcoat better.
Then go buy a TurboCoupe to put them on [Image: biggrin.gif] LOL !
Dan Eaves
Dan Eaves
