Turbo coolant hose
RC Martin Offline
Anybody know what size it is? The little 2" piece of silicone hose that goes to the turbo coolant feed. It looks smaller than the other hoses, so I'd guess 1/2" instead of 5/8"?
I seem to remember its 1/4" ID, but don't quote me on that.
RC Martin Offline
Oh wow that tiny eh. Thought I saw 5/16" mentioned in some searches but nothing concrete. I might try and measure the coolant manifold nipple, mine is slightly corroded though.
Dan S Offline
It's 5/16" OD pipe, I just measured one off an '88 engine.
Dan S
1972 Ford F-100 SWB Styleside
RC Martin Offline
That seems tiny I'm wondering if it is different on the T3 or IHI. I just looked at mine and I'm guessing it's 1/2", I'm going to buy 1' of silicone heater hose and give it a shot.
boboli Offline
Make sure you get high temperature hose or it won't last long.
I replaced the lines on my 86 turbocoupe back when I was younger. I figured it would be fine. Drove 80 miles towards Phoenix and decided to pull into a rest stop and pop the hood. Opened the hood and found the coolant feed hose on fire! Thankfully, I had all the parts to replace the hose and I drove back home instead of pushing my luck further. I ended up at Grainger, buying high temp hose and a heat sleeve for good measure. No more problems after that.
RC Martin Offline
boboli Wrote:Make sure you get high temperature hose or it won't last long.
Any recollection of what size hose you used?
boboli Offline
Sorry, that was 1996, and about 8 cars ago. I can't recall what I used and all the receipts are long gone
5.0TurboCoupe1988 Offline
the hose is 1/4" ID
1988 TC 2.3/5-Speed, 148K
RC Martin Offline
Finally changed it out today. There's no chance in hell it's 1/4" ID, that must be for the IHI on the 87/88. My 84 has 85/86 style coolant manifolds and engine with the T3. I used a 1/2" silicone hose today and it worked great, it could be 7/16" or something but the old hose piece was too deformed to be able to tell.
