Turbo coolant feed flare fitting size?
John B Offline
Hey, does anyone know the thread pitch of the flare fitting for the turbo coolant feed line? I broke the hard line so I'm going to remove it at the flare and replace with an equivalent size fitting that has a barb end for a hose. Thanks
John B Offline
I figured it out; the coolant feed fitting is 1/2"-20 inverted male fitting. Very hard to come by but if you're in a pinch (like me), NAPA has a generic brake line where one end is 1/2"-20. The part number is 813-1159. The brake line will have to be cut fyi
