Machzman
Jul 2003
Carmel,Maine
Does anyone run the turbine wheel from the GT? If so what size tires are you running? Also will these fit on a 88 TC? Thanks for any help Rod
Trying to get under 13sec.http://www.cardomain.com/ride/2546941/1986-ford-thunderbird
Glenn 88TC
Lebanon, PA
Not running them but they will fit. There is a burgundy 88 near me with them on. I like the way it looks.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), Solid lifters, Esslinger roller cam #2277, Esslinger adj. cam pulley, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Spec stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
TurboPower
Jul 2004
Huntington, New York, USA
I use the them on the rear in the winter with snow tires. size will be different for normal use, but they do fit.
87 Turbo Coupe, All Stock, Daily Driver.
Jim Lewis
BCA
May 2001
Dowagiac, MI
BCA
The 16 spoke "turbine" wheels from a Mustang GT are 15"x7" with a 5" backspacing.
Dimensionally they are exactly the same as the '85-'86 TurboCoupe & XR-7 10-hole wheels.
A gold version of this wheel was used on the 1987 20th Anniversary Cougar.
And in 1988 it became the standard equipment wheel on the XR-7, it came painted to match the body color of red, black or white. But the argent color was an option.
Brent
1985 Cougar XR-7 5-speed - 1 of 7,860 built
1986 asc/McLaren EuroCoupe - 1 of 47 built
1971 Ranchero
NATO member
1971 Ranchero GT
Keith Pellerito
Aug 2004
Fenton, MI, U.S.
I had them when I first got my bird--yes they fit, the tire size on them was 215/60 vr15 goodyears I believe. For a good look though, go wider--looks more aggresive.
yeah it is fast, just a little slow getting back to the garage!🚓
