Tubular Control Arms
Carcrazyscott Offline
Doing a little checking on a common topic of discussion here. It was talked about before with X2C making control arms for TC, but pretty much died because of the number of people needed to get the ball rolling (100 people). Well, I'm interested to see what kind of response we would get if S&R started producing control arms for the TC's. Lower sets at first, but shortly afterwards upper sets as well. Price would be in the $125-$150 for a pair of lowers made out of aluminum with polyurethane bushings installed. We'd need 25 people to commit to a pair of lowers to be able to get all the materials needed to start making them. Production could start as early as a week and a half. Let me know what you guys think and who would be interested.
Also, Nate K. if you happen to read this, shoot me an email. I need some info that I forgot to get from you at Carlisle. Thanks a bunch
-Scott Ressler
S&R Racing
Updated Site-finally http://www.angelfire.com/pa5/srracing/srracing.htm
Glenn 88TC Offline
Once again I was volunteered to test them. I promise to beat the ever lovin $hit out them.
I guess that means I'm in.
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
karnage Offline
Count me in.I will need a new set when i do my 8.8 swap in the TC.
Fox ThunderCats Offline
Apparently the GM A-body (Chevelle) upper arms from Jegs fit perfectly into our cars:
http://www.cougarnuts.com/board/showthread.php?t=6364
And here they are: http://www.jegs.com/cgi-bin/ncommerce3/P...rmenbr=361
Sam's Fox ThunderCats ... Your home on the web for fox Thunderbirds and Cougars
mjbtbrd Offline
i could very well be wrong but don't mustang lowers fit?
does anyone have experience with the urethane bushings? I am concerned about them being noisy
No, the Mustang arms don't fit because they are too short.
I have polyurethane bushings in my stock control arms and they aren't noisy at all. If you have the proper lube on them, you don't get any noise.
-Scott Ressler
turbocoupes Offline
count me in for a least 2!!!
Birdoprey always in flight
83 86 87 87 87 87 TC 87 XR4ti
Garry McVey "BIRDS OF A FEATHER" TBird TC owners are usually wingin' it
TC's 83 project, 86 donor for 83, 86 FUN street car daily driver with speed equipment from Red 88 donor, 87 blue to be stock street car, 87 red donor for blue and others, 87 red donor, 88 street and strip(now a donor) 14.01 chasin 13.0's, 87 XR4ti project,
Chuck W Offline
I was not impressed with the X2C arms when I saw them for the Mustangs. I think Stinger over on turboford might be having "issues" with his uppers, nothing has been determined but keep an eye on THIS THREAD . I think it's a case of "you get what you pay for". Are the S&R arms going to be any different?
I personally am not interested in a set....
83 Pseudo-Coupe, 87 Ranger (soon to be 2.3T), 84 XR7, 86 XR4 and 62 Mercury Monterey (old n slo)
jabobia Offline
hey i posted on TF also...count me in [Image: biggrin.gif]
-james
87 TurboCoupe - 5spd
87 Thunderbird TurboCoupe - 2.3T, T5, 3.55L - K&N, 18psi - 16.14@88mph(2.37 60')
88 Thunderbird Sport - 5.0SO, AOD, 2.73L - 16.77@82mph(2.39 60')
www.cardomain.com/id/jabobia
jabobia.com
If you make them I will pay [Image: biggrin.gif]
