(This post was last modified: 03-11-2019, 07:31 AM by andrewjs18.)
I have an 87 TC and we all know how lousy the headlights are in these cars with the stock halogens, especially if you don't have mint chrome/mirroring in the housing. My housings have absolutely 0% chrome/mirroring in them and I'm not about to shell out ~$400 for a mint seat of headlight housings to put halogens back in them - I personally hate the look of halogen bulbs in any car.
I wanted to try out a high end set of LEDs in the car that'll plug directly into the factory harness without any modifications - the 87-88 tbird uses 9004 bulbs/wiring. I'd prefer not to modify the housings to fit projectors for HIDs so this was the first step to see if the LEDs I was looking at would hit a few things: brightness, beam pattern and lack of light scatter. I ended up picking up a set of the supernova v4 LEDs from headlight revolution for $170. They're definitely expensive but get very high marks and are some of the brightest LEDs on the market with great beam patterns that tend to match the halogens.
First, a photo of the LEDs and how they look in a spare housing I have without the lens:
![[Image: d4YNo9x.jpg]](https://i.imgur.com/d4YNo9x.jpg)
![[Image: 1BUQgAa.jpg]](https://i.imgur.com/1BUQgAa.jpg)
![[Image: WmtOfWN.jpg]](https://i.imgur.com/WmtOfWN.jpg)
Here's a few photos of the stock halogens in my TC. Keep in mind that I have 0 chrome/mirroring in my housings and my left headlight housing is leaking. This was approximately 25ft from my garage door at around 7pm at night. It was pretty dark, with the exception of my neighbor's deck light that added some lighting but nothing that would throw off the testing, I don't think... my car was also running so the lights got the full amount of juice for testing purposes.
![[Image: uBe3kSw.jpg]](https://i.imgur.com/uBe3kSw.jpg)
![[Image: YYiyVVV.jpg]](https://i.imgur.com/YYiyVVV.jpg)
![[Image: eDLGXIa.jpg]](https://i.imgur.com/eDLGXIa.jpg)
Both LEDs in, same distance and parameters that the halogens were tested at:
![[Image: cKQYKZf.jpg]](https://i.imgur.com/cKQYKZf.jpg)
![[Image: 1ouNCxb.jpg]](https://i.imgur.com/1ouNCxb.jpg)
![[Image: hKa96xr.jpg]](https://i.imgur.com/hKa96xr.jpg)
These are VERY BRIGHT with an excellent beam pattern that mirrors the stock halogen bulbs, but the scatter is awful, as you can see in the above photos...
Here's a few photos of the LED light with the locking retainer attached. This specific set of LED lights has an allen screw that you remove so you can slide the locking retainer down onto the heatsink to lock the LEDs into the housing. The problem I found with my old retainers is that they're very deep so they cover almost the entire heatsink and they tabs inside the retainer that act like a stock for the lights are very brittle with age...I broke a few. New model retainers can be bought for a little less than $7 per retainer on Amazon thanks (BJL) and are about half as deep.
![[Image: QRWPUcx.jpg]](https://i.imgur.com/QRWPUcx.jpg)
![[Image: SiiwzWw.jpg]](https://i.imgur.com/SiiwzWw.jpg)
![[Image: s03FV2k.jpg]](https://i.imgur.com/s03FV2k.jpg)
![[Image: TIHDhAY.jpg]](https://i.imgur.com/TIHDhAY.jpg)
![[Image: Qwrp2a1.jpg]](https://i.imgur.com/Qwrp2a1.jpg)
Being that I have a spare housing that doesn't currently have a lens on it, I figured I'd try an LED light in it to see how the LED would look if I were to sand the inside of the lens smooth (I can't see why it wouldn't mimic this output at least..).
![[Image: A2pXZni.jpg]](https://i.imgur.com/A2pXZni.jpg)
![[Image: LoNbClv.jpg]](https://i.imgur.com/LoNbClv.jpg)
![[Image: XYugDhK.jpg]](https://i.imgur.com/XYugDhK.jpg)
![[Image: PafYrwj.jpg]](https://i.imgur.com/PafYrwj.jpg)
![[Image: baUxYxK.jpg]](https://i.imgur.com/baUxYxK.jpg)
bright, with no more scatter, but the beam pattern is pretty blah...reminds me of what you'd find with an LED flashlight...
https://tbirdcougarparts.com
-Andrew
-Andrew
