i have a aftermarket alarm that requires a relay to make the trunk pop. this is what i have so far
* RELAY COIL #85 (coil power) = Coil Power to a Fused , "Hot at all times 12 Volt Source"
* RELAY COIL #86 (Coil Ground) = Coil Ground To the remote "Opener switch"
* RELAY CONTACT # 87 (Normally open Contact)
= 12 Volt FUSED battery Source.
* RELAY CONTACT #30 (Center Wiper or movable contact) = Trunk motor opener Power wire.
* RELAY CONTACT #87a (Normally Closed contact) = Is not used for this application.
can anyone tell me what would be a good way to do this or where can i find these wires to install the relay
thanks
thanks
86tc 5speed k&n, gfb boost controller, autometer gauges, tripminder, fmic, and upgrading as fast as possible
