(This post was last modified: 07-15-2013, 11:14 PM by Superman1307.)
I finally have my 88TC running again when I drive it is fantastic. It runs great till about 15-20 minutes in to the drive, once I come to a stop at a stop light and sit for a minute, it starts clattering like a diesel just sounds like crap and loses power badly. I just got done rebuilding the motor it is bored .02 and stock stroke. I replaced the IAC valve, TPS, and my faulty knock sensor. I also double and triple checked fuel pressure, cam and distributor timing all is good great spark and no codes coming from the computer. The car does not over heat or even get close to getting to hot, I just can not figure out why it would do that, it only takes a minute or three to get up to temp don't why it would run perfectly for that long and then run so horribly. Any help or suggestions would be greatly appreciated.
