trouble boosting
k98311 Offline
so if i only boost 2-3 pounds itss fine but if i go over that i loose power, but if im at 3 grand or more then it gets about half power and goes. ive replaced the fuel pump the fpr and fuel filter any ideas?
What fuel pressure readings do you get at idle?
Vacuum / pressure leak? Carefully check the IC hoses for cracks, leaks, etc. Some cracks only open under boost. Also be sure all hoses are securely clamped.
jmthunderbirdturbo Offline
could be VAM hose closing up, ive seen that. which pump did you replace? don't 86's have two, a volume from the tank and a high pressure on the frame canister?
could also be blowing out spark from weak wires, dirty or poorly gapped plugs, or a failing coil.
when you replaced the fuel system components, did it change anything?
any other mods besides what in your sig?
-J0N
k98311 Offline
Sorry for the delay guys broke my WGA snap ring off, its a bitch to find one that small! before boost would just slow the car down but now after my changes it only responds well to boost after 3 grand
My mods are as follows
FMIC
WGA runs off vacuum tree boost
Running only 10 pounds right off the WGA
Cat delete
straight through muffler
cone filter
New 255 pump
umm i think thats it.haah
k98311 Offline
and i was 90% sure there was only one pump on the 86 may be completly wrong though
ill probably change the coil next week i just did the wires and plugs though ( upgraded to some e3's!) after changing the pump is when i noticed the difference though
TurboBoost88 Offline
I thought the 86 and down had 2 fuel pumps ??
one frame mounted high pressure and one low pressure in tank
I'm pretty sure the 86s were a one pump in the tank setup
Not B Anymore Offline
Pete D Wrote:I'm pretty sure the 86ss were a one pump in the tank setup
Yup
