@%$#$& Trim pieces
lmp320 Offline
okay, it has almost gotten to the point where my bird is going to be done, and the only reason i can't drive it is because of the trim i can't find. I need the window channeling for both doors. and i also need the outer window rubber piece that attaches to the chrome for both doors. if anybody has any idea where i can find them (and don't say junkyards, cause the first 4 have been useless), please let me know. i heard someon esay that they thought the channeling for the same year(s) Mustang is the same, and to order it and make it fit. i just need something that fits and looks good. i know many other TC owners have had the same problem. is ther ANYBODY out there who sells these things new anymore?
Blade1433 Offline
Junk, err....body shops. Call around, or better yet, visit some of the local body shops, they should be able to refer you to suppliers and NOS warehouses
Blade
"Drive it like you stole it"
88 bone stock TC with 138k, 5spd, burgundy, almost all options with new U-joints, tranny Xmember, front end, FULL tune-up with select MSD products, new horizontal axle shock thingies, custom interior, white face guages. Coming soon: boost guage and air fuel ratio guage on the pillar, Gillis valve, K&N, gutted upper, knife edged lower, gutted E6, T3, and steam cleaned engine bay.
BJL Offline
Moderator
Speicify the trim peice i have two rusted out doors with all the window trim still on, are you talkin about the trim on the outside of the channel that the windows runs down inside the door?
Brian J Larkin
1988 Turbo Coupe 5spd, dark blue and shining like a peice of polished glass.
http://crazydriver358.5u.com
Brian Larkin
88TC 330,000 miles
Slightly Modified
lmp320 Offline
i need both the channeling that the window goes in, both doors. then i need the outer rubberstrip along side window base, when rolled up. the outside strip.
Turbo Joe Offline
Try Green Sales in Cincinatti, OH. They buy nos parts from Ford dealers and resell it. Reasonable to Ford dealer standards. I bought a drivers side body molding for $116.00, where a dealer wanted $190.00, if he could find it. They have an 800 number for purchases, if you know your part number,(dealers are good for something), If you want them to help you with the part number, the calls on you.
87 Turbo coupe, 5-speed, K&N cold air cone, T3/T4, Gillis boost valve, ATR header, 3" Downpipe, Kirban fuel regualtor, 255 Walbro pump, UR underdrive pulley, ranger cam, fresh bottom end, Pro 5 shifter, fresh brown tops, Eibach lowering springs, new factory PRC shocks and struts. Working on a FMIC.
