Here is the problem, after a highway run (or warmed up) the idle, in stop and go traffic will stick up at about 2k rpm. When I kick the throttle I can get it to settle back down to about 1k.
Now, I have replaced the TPS, set at .95/.96.
Replaced the IAC after I cleaned the one I had (blasted out with brake parts cleaner) and neither made a differance.
Cleaned out the EGR. Checked for Vacuum Leaks. I ran codes only to repeatedly get 11's. I am completely at a loss. I dont know what else to try?????
Does anyone have any suggestions????
85TC, Custom cold air intake,K&N Cone, Intercooled, Gillis Boost Valve 18PSI, Spearco BPV, Full 3" Exhaust,with a Vortex Muffler, Looking for more Boost! NATO member (Chris Taylor)
86 Camaro, 5.0L, 4bbl, K&N, MSD 6200 6A, Dynomax cat back system, Pace Setter Shorty Headers, I think I will just sell it so as to make room for an SVO !
Christopher Taylor
85 TC, 2.3l, LA3, T3/T4 Turbo 25psi, Stinger FMIC, Forge BOV, Full 3" Exhaust, Esslinger crank pulley- Timing Gears and overdrive WP pulley, BBK 255lph FP, Kirban AFPR, Kirban Shifter, K&N Cone, 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, Welded SFC's, and TON's of other parts.
