Transmission wiring help needed!!! ASAP
t-bird88 Offline
I had to pull the motor out for some repairs, long story, and after the second time of pulling the motor and the 3rd time of pulling the transmission I got a little bit upset. The last time that we pulled it was as a unit (engine and transmission, well, I forgot to unplug the VSS and Neutral safety switch. The question that I have is which side of each plug are the colored wires. There is a white and black pair of wires on the neutral safety switch, but which side are they on? And as for the VSS, which side is the orange wire and green wire on?
Thanks in advance guys!
Jim B Big Grin .
Gunmetal Grey 88 TC!!!!
I hate when that happens Big Grin
The 88 EVTM shows R/LB from the START post of the ignition switch to the Neutral Safety Switch and a W/PK wire from the other side of the NSS to the trans (manual)
The DG/W side of the VSS goes to several places including the EEC, pin #3. The other side of the VSS has a O/Y that terminates at ground G903
Check your email.
