firstsvo
Mar 2004
miller place, ny usa
'88 TC auto. The car doesn't go into lockup when it gets hot, been that way for a while. I thought it was due to the engine running hot, but tonight it was nice and cool out, engine temp was at its normal 210* but lockup worked perfectly, so I'm figuring it's the trans temp, not the engine temp that's the problem. The cooler on there now is about 11"X4". I was looking at a fluidyne cooler that is 14"X6.5" but a different design and supposedely 50% better cooling than the normal fin units. There are bigger coolers, but my concern is how big is too big as the car runs hot as it is in the summer (like 220*) and I don't want to block TOO much of the rad. Any ideas of what size is best and what brand and type? Thanks... Chuck
DonH
Jun 2002
Central Massachusetts, USA
Converter clutch lock up is controlled electrically by the by the EEC so the engine running conditions as determined by the various sensors is important in relation to the lock up function. Failure to lock up can be caused by malfunctioning ECT, TPS, MAP, or BOO as well as bad electrical connections to the lock up solenoid or to the failure of the solenoid. The other possibility involves contaminated fluid. The lock up will not happen if the EEC thinks the engine is too hot or not producing enough power.
1987 TC stock except ATR 2.5"
firstsvo
Mar 2004
Then why does it work when the engine is hot but the air is cool? Also, if the car idles in Park to get up to temp.(like when I "burped" the radiator) it also worked. I am about 99% sure it's the tranny temp thats messing it up. I've been bitten by that 1% before on this car, but I'm pretty sure. Better tranny cooler can't hurt and it's pretty cheap, so I think I'm going to get that one and see what happens. Also, a tranny guy I mentioned this problem to said there was a temp sensor in the tranny. I don't know. Seems logical.
The "old" not 100% electronic A4LD used in our cars does not have a temp sender in the tranny. The fully electronically controlled versions of the A4LD (4R44E, 5R55E, 5R55S) used in later model cars / trucks do have temp senders to measure tranny fluid temp.
CougarXR7
Jun 2006
Marietta, OH
You're correct about the design of the cooler.
A "stacked plate" design is more efficient than the traditional fin & tube style.
I put a 24k stacked plate on my '96 XR-7, which has the 4R70W transmission. This style and size is highly recommended from the MN12 people.
Did you bypass the stock cooler in your radiator?
1986 Mercury Cougar XR-7
5-Speed - Leather - Dual Manual Seats - Vent Windows - Smokin' T3
firstsvo
Mar 2004
No, that was my next question. I was not going to bypass it, but I wanted to know which line was in and out of the rad (as in is the top line going into or coming out of the rad) so I could have the cooler be the LAST thing before going back to the tranny. Thanks... Chuck
DonH
Jun 2002
While you are putting on the transmission cooler why not add a remote filter too. That wouldn't hurt either.
firstsvo
Mar 2004
Never thought of that. Good idea. What about the which line is the "in" at the rad.?
